Hitec eclipse 7 issues
Maybe some can answer and correct this problem I am having with my Eclipse 7 in Heli mode.
I am setting up my 450 using the Eclipse 7 transmitter. All is good untill it comes to the 3 different flt modes. I first set all dual rates off, Inn all mixing modes, and swash setting are equal in all modes. The throttle and pitch curves are identical in all 3 modes. In normal postion all is good, swash pitch is ok and normal operation. In ST1 mode all is good, swash pitch is ok and normal operation. In ST2 mode 2 of the swash servos will move out of plane and cause the pitch to rise and alerion servo of drop about 2 degrees off level plane. Also when the Flt cond switch is moved forward ST3 will also make the servos go off center. I have checked all trim, sub trim, dual rates, EPA points, prog mixes 1 and 2, throttle and pitch curves and cannot find where any changes to the setting have changes in these 2 modes. Any ideas where or what I am do to get all modes the same? Larry |
RE: Hitec eclipse 7 issues
Man do I feel stupid:eek:
Found the problem in the stored trims. I checked the sub trim settings and not the trim settings for those flt modes...... :) larry |
1 Attachment(s)
ORIGINAL: lbarnes Maybe some can answer and correct this problem I am having with my Eclipse 7 in Heli mode. I am setting up my 450 using the Eclipse 7 transmitter. All is good untill it comes to the 3 different flt modes. I first set all dual rates off, Inn all mixing modes, and swash setting are equal in all modes. The throttle and pitch curves are identical in all 3 modes. In normal postion all is good, swash pitch is ok and normal operation. In ST1 mode all is good, swash pitch is ok and normal operation. In ST2 mode 2 of the swash servos will move out of plane and cause the pitch to rise and alerion servo of drop about 2 degrees off level plane. Also when the Flt cond switch is moved forward ST3 will also make the servos go off center. I have checked all trim, sub trim, dual rates, EPA points, prog mixes 1 and 2, throttle and pitch curves and cannot find where any changes to the setting have changes in these 2 modes. Any ideas where or what I am do to get all modes the same? Larry Suggest reset, or try on another model number which has been reset to factory default, and start again. The attached . Eclipse Helicopter Set Up Chart . Eclipse Heading Hold Gyro Set Up may assist. Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links Later: Post #2, despite time showing to be 10 minutes earlier, was not displayed when this answer posted - must have been a lot of traffic?. |
