eclipse dual elevator function
Not so sure where to post this so will post on this general forum;
Been away from site for long time I read from the preacher on how to program dual elevator function and using the digital trims to conrol the elevators together unoppossed. plug ch2 and 7 with 2 as master. Now when I plug 1and 6the ailerons work finebut one of the elevators move intune with themwhen I slide the ail digital trim. I;m at the point of going back to two "Y" harnesses dazzed and confused Roger. I'll really be happy when my new aurora comes in!! |
RE: eclipse dual elevator function
1) Make sure you dont have another mix enabled that would link the one elevator to the aileron channel.
2) Does your radio have the AILV mix in it? If so then you can use this mix to have dual elevators and not use a P-mix. 3) Can you test this same mix on a new model memory and see if it also links the one elevator to the aileron trim? |
