Powersafe RXs and HS7950 servos
There has been forum post on 7950 servos not working well at high voltage with extensions longer than 24inchs... Cody Wojcik from hitech states that their data shows that the signal strength put out by the powersafe RXs is not strong enough to run the servos at high voltage. I have a JR1222 that I would like to use with these servos at high voltage. The current suggested fix is to put one of your inline signal boosters on the servo extension. http://www.spektrumrc.com/Products/D...x?ProdID=SPMCP Do you have conclusive data that shows the suggested will fix the problem. Results on forum post seem mixed. Secondly are their any fix this problem? I have over $200 invested in my rx and I don't want to have to add/replace with another solution. I would really prefer not to use the signal booster.
