Hitec Spectra Module compatability wit Futaba 9c?
I saw that the Hitec Spectra Module should work with Futaba 9c. Purchased Module with Optima 7 receiver, but cannot get it to bind and work properly.
The Module and receivers work correctly with my Eclipse radio, but will not connect properly with my 9c radio. Is there another binding procedure for the 9C, other than that in the module manual? Thanks in advance for your help. |
RE: Hitec Spectra Module compatability wit Futaba 9c?
It does work in that radio as many have used it to convert over to 2.4. No special binding procedure is needed. Make sure the Tx is set to PPM (FM) modulation (not PCM) and that both the Tx and Rx batteries are fully charged when you do the binding process.
You are correct. When I removed my thumb from my ear and set the radio on PPM, it works correctly.
Thanks |
So if the Hitec 2.4 module works in the Futaba, does the Futaba Spektrum module work in the Aurora 9?
ORIGINAL: Kimhoff So if the Hitec 2.4 module works in the Futaba, does the Futaba Spektrum module work in the Aurora 9? Aurora A9 - Module Pinouts and Compability Hitec Spectra, standard and other brand modules are not compatible. <font size="1">Details and pictures.</font> Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated} Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
