Aurora 9 transmitter firmware upgrading connections and procedure ?
I have a new Aurora 9 and the HPP-22 PC programmer. I successfully upgraded the firmware in 3 Optima receivers. However, I have not been able to figure out how to upgrade the transmitter firmware. I have used the following procedure:
1. connected pc to HPP-22 with USB cable 2. connected HPP-22 P1 port to transmitter trainer port The transmitter manual shows the system update port of the module. Where does the other end this cable plug-in ? I tried HPP-22 ports P2 and P3 with the following message being displayed...."transmitter not connected". What is the correct connections and procedure to upgrade the transmitter firmware ? Thanks.....George Bonn |
RE: Aurora 9 transmitter firmware upgrading connections and procedure ?
Are you plugged into the correct jack on the Tx. The view in the HP22 video is not correct. Igot it to work. Do you have the latest software for HP22. Early version did not work.
JIm D. |
ORIGINAL: georgebonn I have a new Aurora 9 and the HPP-22 PC programmer. I successfully upgraded the firmware in 3 Optima receivers. However, I have not been able to figure out how to upgrade the transmitter firmware. I have used the following procedure: 1. connected pc to HPP-22 with USB cable 2. connected HPP-22 P1 port to transmitter trainer port The transmitter manual shows the system update port of the module. Where does the other end this cable plug-in ? I tried HPP-22 ports P2 and P3 with the following message being displayed...."transmitter not connected". What is the correct connections and procedure to upgrade the transmitter firmware ? Thanks.....George Bonn Please refer to Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to install & Use Instructions <font size="1">(with screenshots)</font>. <span style="font-size: smaller">and more at Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated} </span> Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
