RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   Eclipse 7 TX battery (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/996013-eclipse-7-tx-battery.html)
Sarj 07-27-2003 12:37 PM
It takes 15 hours for the first charge. What about the following situations, using charger supplied with the transmitter:
1. Time required to charge after the low battery alarm comes in
2. Time required to charge if the TX has been used for only 60 minutes
Also please let me know if the battery will be damaged if it stays on charge for extended periods ( Greater than 24 hours)
MikeMayberry 07-29-2003 10:02 PM
Just plug it in the night before you plan to use it. You can't overcharge the battery, even if you leave it on for days!
The charge rate is 50Mah.
Mike.
