Hpi Savage SS 4.6 swapped with losi 454
So I'm switching my k4.6 out of my pretty stock savage SS 4.6 with a losi 454. How do you think the truck will take the 454? The only other thing I'm replacing is the plastic spur with the heavy duty spur and hardened cb. What do you guys think?
VT
RE: Hpi Savage SS 4.6 swapped with losi 454
it should come with a HD CB and spur, the only change i'd do is swap pipes, and maybe get some aluminum shoe's i've heard good things about the losi sport HT pipe, or an dynamite 086 for that motor, i think, seeing as it's an lrp .28 at heart
the lug
the lug
VT
ohh my bad, in my exp, which isn't all that great, i had better luck with the plastic pipe on the x 4.6 than with the metal polished they have on the SS, but thats just me, and then as far as upgrade CB and spur, that wouldn't hurt at all, tho i like to run a plastic spur, cuz it's a cheap failsafe
the lug
the lug
Oh ok, I haven't had any problems with the tuned pipe on the 4.6. I ordered the hd spur and cb cuz I already was stripping the plastic with the 4.6 and was getting kinda tired of buy plastic spurs over and over again..
the losi ht pipe n 086 r 2 diff pipes.ht means high torque and the 086 is a top speed pipe.ive used both and they both r great.depends on wot u want.top speed? go the 086.if u want supercross style short run ups for jumps n jumps then go ht pipe(007)
