curious why not
AZ,
curious why not
Would there be any reason why rubber engine mounts wouldn't work with these engines or do they absolutely need to be solid mounted?
Jon
Jon
FL
RE: curious why not
ORIGINAL: z style
Jon
Jon
RE: curious why not
also the engine plate helps dissipate heat as a heatsink, which if there was rubber it would insulate it instead probably causing your engine to run hotter.
AZ,
RE: curious why not
it's been a long time since i've messed with these rc trucks. You're right though, i couldve answered the question myself. I was thinking more of the lines of an actual car engine and didn't think about how the gear mess is lined up. silly me.
NY
RE: curious why not
LMAO! Yeah they would move together, AWAY from each other!! It would never ever work.
ORIGINAL: megamaxx
the question kind of answers itself if you reallllllllllly think about it!!!!! but in theory if ya put the tranny on rubber mounts too they could move together,.....problem solved!!!!! LMAO
ORIGINAL: z style
Jon
Jon
