HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
slipper nut to tight??
Old 07-17-2011, 09:31 PM
canas11267
Default slipper nut to tight??
i just bought a robinson racing pinion gear and installed it. before installing it i tightened down the slipper nut. Then Iinstalled the pinion and put blue locktite on the set screw. when Ihit the throttle the set screw comes loose?? any suggestions?? the only thing Ican think of is the nut is possibly to tight?? it will run for 20 ft or so them come loose? it also rolls freely so its not binding.
Old 07-17-2011, 09:35 PM
Freezetron
Default RE: slipper nut to tight??
Just replace it if it won't stay tight
Old 07-17-2011, 09:41 PM
canas11267
Ijust replaced it and put locktite on it. so i will let it sit overnight and see what happens. its already late.but is it possible to overtighten the slipper nut??
Old 07-17-2011, 09:52 PM
xerxes
xerxes's Avatar
loktight takes 24hrs 2 dry. it wont do any good unless its dry. & dont lock tight da slipper nut. just doublenut it.
xerxes alredy told u da slipper clutch is useless. tightn down as hard & far as it can go.
Old 07-17-2011, 09:58 PM
canas11267
I got the robinson racing slipper clutch its huge there is no way you are double nutting that thing! i will post pics tomorrow...the side of my bottle was worn out so i didnt see how long it took to dry. however, I will let it set. I really tightened the slipper nut down so I will keep an eye on it. Ialso ordered a castle parallel conector so Icould tone down the 6s and get a longer run time
Old 07-18-2011, 01:26 PM
Savage-Basher-666
What about adding more washers?
