HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
What RC Truck Do i Have?
Old 10-08-2015, 11:41 AM
FM696269
Default What RC Truck Do i Have?
Hey guys, first post here and probably a noob one but here goes. I bought a HPI Savage today from a guy at work, ive had it running and apart from a weak brake, its all good as far as i can tell. Only problem is, i have no idea what savage it is, can anyone tell by looking at the pics? also what size engine is in it?
Cheers
ID:	2124413   Click image for larger version
ID:	2124414   Click image for larger version
Old 10-11-2015, 06:19 PM
PaulDeth
PaulDeth's Avatar
redcat blackout xte
Old 10-12-2015, 06:19 AM
Maj_Overdrive
Maj_Overdrive's Avatar
I'm not familiar with the different visual cues of Savages. There's the .21/.25 and then the Savage X as far as the chassis is concerned. For the engine have a look at the sides of the block behind the pipe and fuel tank. There's markings under there telling you the size and type. That looks a HPI .25 but it could be a F4.1 as I'm not that knowledgable with HPI engines.
Old 10-13-2015, 06:47 AM
-SomeGuy-
-SomeGuy-'s Avatar
You have an old school savage 25 with aftermarket HPI plates, a K4.6 engine, dirt bonz tires, HPI tuned pipe, steel spur gear and hardened clutch bell, HPI wheelie bar, inline fuel filter on top of the one built in the fuel tank. Good little setup, the engine would be your weakest link as they were not the strongest or most reliable. Easily fixed with an upgrade to an LRP .28. You need to change the air filter to a two stage ASAP! Plus it looks like your engine might have overheated at some point, see how the bottom fins are discolored? That's how I know. Apart from that, looks like the previous owner knew a thing or two about these and had no problem tearing it down and rebuilding it. They are pretty much bullet proof trucks and newer models have only gotten stronger to compensate for the bigger engines and the FLUX of course.
Old 12-30-2015, 06:40 AM
CapeTruckMan
Why the pic of the Redcat Racing Blackout, just curious? I bought the Blackout XTE Pro with low expectations and have been blown away by the performance and durability, for $200 this thing is a beast right out of the box.
Old 04-27-2016, 01:30 PM
Bobby26
If you put a Picco 28, THS pipe, 3 speed tranny and robinson racing gears, you will have yourself a wheely machine.
Old 05-04-2019, 12:57 PM
nightspeed98
is the Picco 28 any better than the Force 32?
Old 05-04-2019, 12:58 PM
nightspeed98
I've had robinson gears since 2004. I have NEVER damaged one.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
