HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
savage fuel tank...
Old 01-24-2004, 07:04 PM
cncman
Default RE: savage fuel tank...
Adrenaline Rc has upgraded thier savage fuel tank guard to fit the new 25 ss tank.It also fits the original 21 and the ofna tanks
Old 01-24-2004, 10:41 PM
mike1288
mike1288's Avatar
I just ordered all the parts to do the dual tank setup on my Savage. I'll post pics when it is done.
Old 01-24-2004, 11:41 PM
Vintage_Duff
wat is the web site to get
duel fuel tank
Old 01-25-2004, 12:52 AM
Vintage_Duff
and also will fitting this
do the same job as badboy2 and
mcvickj second fuel tank
[link]http://www.neweramodels.com/cgi-bin/item.cgi?session_id=dtmnsvvbrohxastqfdkrcrmaabmkbp aq&part_id=1853[/link]
Old 01-25-2004, 08:05 AM
creeping death
ORIGINAL: Hell_Savage
yea, but thats a rear mount for the twin motor savage...order the regular one and it mounts to the side like stock...they have it on the same site.
Old 01-25-2004, 04:57 PM
  #31
Vintage_Duff
i know its for the twin savage u put the rear tank on keep the normal one
and u will have 285cc the fuel tank that mounts on the side is ownly
125cc u loose running time
Old 01-26-2004, 03:22 PM
  #32
creeping death
so ur using the ofna rear tank as a header tank? cool.
Old 01-26-2004, 08:48 PM
  #33
Vintage_Duff
Default RE: RE: savage fuel tank...
i want to know if u can use the ofna rear tank from newera
as a header tank because u would have so much more running time instead
of using the 2oz tanks
i just want to know if the newera tank will fix the leaning problem
Old 01-27-2004, 06:46 PM
  #34
Vintage_Duff
answer me please can i just use the
ofna rear tank as a header tank and will it fix the leaning problem
Old 01-27-2004, 08:22 PM
  #35
Savage 24651
Can someone tell me what causes the lean out problem. Is it a fuel pressure problem?I am new to the RC world . I built a Savage SS and love doing it. I started it as stated in the instructions. It started to lean out after a half tank. I let it run 3/4 tank out and checked the tempeture. To my supprise it was 285 degrees. I shut it down.
Old 01-29-2004, 06:54 PM
  #36
creeping death
i think it has to do with the design of the tank...and i don't know if the ofna rear tank can be used as a header, but i would think it would.
Old 02-16-2004, 12:56 PM
  #37
creeping death
well, now my ofna tank is self leaning, and i have tried every needle adj. possible...guess I will go for dual tank mod now...does this have a special pickup or something, that eliminates this problem...thx.
Old 02-16-2004, 03:20 PM
  #38
03 DSG Snake
When using the heli rear header tank, I heard it has to be filled/primed seperately. Is this true?
Old 02-16-2004, 07:13 PM
  #39
psykosavage
ORIGINAL: 03 DSG Snake
This is true, but very easily accomplished. You can pull the pressure line off the exhaust and blow into it. Then just don't run the tank dry all day and you won't need to re prime it. At the end of the day I just run it as dry as possible and dump the extra.
ORIGINAL: HELL_SAVAGE
The reason the Heli style tanks are used more is they are clunker tanks and the pick up will work in any position because it is weighted, also it is a lot cheaper too. Only $2.00 at the LHS for a 2 oz. clunker tank.
Old 02-17-2004, 12:24 AM
  #40
03 DSG Snake
One more thing:
Has anybody found a way of arranging a header tank so it can be used with a ROTOSTART?
Old 02-19-2004, 06:20 AM
  #41
Danno
Danno's Avatar
Here`s mine
ID:	102688   Click image for larger version
Old 02-19-2004, 04:27 PM
  #42
03 DSG Snake
Any details on how you fabbed that bracket?
