spur gears
spur gears
My spur gear keeps on melting.It is tight at the start but after about 1 minute it slips like mad and will Start to melt.I have gone trough 4 spur gears and I am getting a angry.I sometimes want to break the into a million peases[sm=punching.gif].Help I don't know what to do[sm=confused.gif]
RE: spur gears
It is fine at the start but after 1 minute or so it lossens and slips.I've brought it back to the shop and he put in new peaces but it still slips(He put in a new spur gear,a new spring,a new nut,a new washer,and a new ring).But it still slips
VA
RE: spur gears
Given you taosted a new set-up, it sounds like the problem might not be in the spur gear, but in the subsequent drive train. With the motor out, how easy is it to make the wheels turn using the spur gear? How does it coast?
What kind of driving do you do? Have you got some big, grippy tires?
I'd check out the entire drive train to ensure you're not getting any extra drag.
RE: spur gears
Did you properly gap your gears? Too little gap and the gears can bind and melt from friction. Too much gap and the gear will strip. When you gap your gears, stick a little strip of paper...like the kind used in your printer...between the teeth. Press them together tightly and secure the engine screws. ZAM! You just gapped your gears properly. I'm still waiting for my spur to strip or melt.
TN
RE: spur gears
now ive got the same problem as Chello. its not my gear mesh though. mine is set right. its the spur gear slipping when i hit the gas. and the nut is not loose. its tighter than its suppose to be because it slips even more if its at the stock position.
RE: spur gears
I would suggest fitting a new spur gear with a new pad, also, fit a new nut on the spur, the nut should have a rubber bit in the end to hold it where it is set.
Tighten it down all the way and then let it off a 1/4 turn.
I haven't heard of any problems with this set up. Many people with Wasps or Picco's tighten them all the way down and leave them, to compensate for the extra torque.
RE: spur gears
I've tryed all that and it happened again.my spur gear is in the same state as vizaracar's.Also the ring that rubs the pad on the back of the spur gear is covered in plastic.
TN
RE: spur gears
for that ring on the back, im going to heat it up to get the plastic soft and take it off. i may wirewheel it also. i got in the new RR spur gear and clutch bell in today so i will let you know how it does tomorrow.
TN
RE: spur gears
its a thing that spins a wheel that has alot of wire on it and will clean metal. its meant for rust and stuff also. its called a wire wheel.
heres a link to one. http://www.sears.com/sr/javasr/produ...id=00921152000
RE: spur gears
It sounds like your slipper clutch was not properly adjusted in the first place, causing it to slip too much and melt from the heat generated by the excess friction.
I'd say just pick up the parts you need to rebuild the slipper clutch assembly, rebuild it and be done with it.
SiL
SiL
RE: spur gears
why cant hpi just spend a couple more dollars and put a steel spur gear in the savage ss and 25??!?!?!!!! they are such a cheepo company, they dont replace any parts, even though they say it is 'under warrenty'.
RE: spur gears
i think that hpi just hates me cuz they wont replace anything...glow plug, 2 cylinder heads (buttons), dual brakes, stock brakes, pull start, carburator, and the brake linkage. we are all hated in new jersey!
