Problem with Savage???
I was running my Savage 25 the other day and after a stop I gave it throttle to accelerate but it did not want to move. I first thought that the brakes were jammed on or something but after checking them, all was good. I noticed that the big gear from the transmission that engaes the small gear on the engine did not move. I forced it a bit and it finally turned (as if the transmission had seized or something). I proceeded to start the engine again and all was o.k. Any idea what happened here? Have you ever had or heard of a similar problem? Should I tear down the transmission to investigate further or leave well enough alone since its working fine for now?
Thanks.
Thanks.
RE: Problem with Savage???
It sounds like you overheated the clutch and it got stuck in the bell. (The little gear) I would check it as soon as you have a chance. The big gear is called the Spur.
Put a set of aluminum clutch shoes on your wish list. They will not "get stuck" to the clutch bell like the stock plastic ones do (Any they give much better grip!).
