one new tank to rule them all?
WI
i saw some were on here that this one guy had this one tank that was suppose to fix the mid tank lean prob with out doing the whole mod thing
what thread was that in? or you can just tell me what that tank is and post a pic
QC, CANADA
RE: one new tank to rule them all?
I believe this is what your talking about: http://www.neweramodels.com/item.cgi...=&part_id=1704
WI
ORIGINAL: Wisconsin Nitro
it might be but i dunno
how silly of me
well then thanks for showing me it
http://www.neweramodels.com/item.cgi...j&part_id=1853
Imo you should fit that along with the stock tank, more run time too.. And hey, there was a mod like this..
ORIGINAL: Savagekilla
If you want long run times, then get both New Era tanks (side and rear mount) and daisy-chain THOSE.
http://www.rcuniverse.com/forum/m_59...tm.htm#5965359
There's mine installed.
WI
^^^ yep thats the post were i first found it
you get a chance to run it yet? does it work?
and also were did you get the tank from? LHS or the website?
QC, CANADA
That tank is not made by new era, its just a 125cc ofna tank that they are selling with the kit. http://www2.towerhobbies.com/cgi-bin...?&I=LXBM24&P=7
ORIGINAL: alvinm
So its 16 bucks for the mount???
It's a nice kit, but you could likely do it yourself for less. Most of us don't bother with that though. hehe
Runs great and holds a steady temp. through the tank now. I am satisfied even though it cost $20 or so.
It also makes room for the inline servo upgrade should you want to do that as well. Nice kit.
Also someone said something about making it deeper. That won't work as the tank is mounted directly against the TVP, and BARELY fits inside of the body (mine rubs). If you have an LE body like me you won't be trimming the body out just for the tank.
I'm looking into the feasibility of dual New Era tanks (side and rear).
FL
The only issue might be with the vulnarability of the rear tank, especially if you have a wheelie monster. Running without the body would be a definite no-no.
CA
I had the new era tank but had to go back to stock becuase the shock towers that I used placed the shock right next to the fuel output. So unless you are running stock shock towers the new tank will not work.
ORIGINAL: alvinm
Running without the body would be just as *unsafe* as the stock tank on the side which is more exposed than rear-mount.
I don't bash like you guys do, so these concerns are good to point out but don't concern me honestly. I know the truck is meant for bashing, but I'm just not that brutal on my equipment. hehe
