Possible fried clutch and bell
MO
had my motor out rplacing the spur gear and noticed that the clutch bell was sliding on the bearings in side it, about 1/4 in of in and out play. put the motor and all back together and the motot revs like mad but goes kinda slow. pulled it up close and held it with my hand gave it the gas and it pulled a little then just kept revving and a little smoke frome the cb. i have no problem with a new clutch but is the bell supposed to move in and out on the shaft bearings? thanks before hand for the help.
ON, CANADA
RE: Possible fried clutch and bell
that much play in and out.
are you missing the brass bushing of the end of the crank
hpi 86121
http://www.hpieurope.com/piw.php?lang=en&partNo=86121
or the new kit for the x4.6 86171
http://www.hpieurope.com/piw.php?lang=en&partNo=86171
hpi 86121
Even with the brass bushing there is some play.. Mine is like that, 1/4 inch is a alot though..
Chances are your spur gear is loose.. Mine kept spining loose, I put a second 7mm lock nut behind it to keep it from spinning loose..
MO
i know the spur gear is not loose cause i took the spring off and replaced it wit a thick lock washer and a slightly larger nut in front of that and put the original nut back on with lock tite and cranked until it was all the way tight. i haven't torn it apart yet doing that tommorrow and was gonna try my alluminum shoes from other truck but am hessitant about the cb. the cb screw is all the way tight but it doesn't have any washers behind the screw, is it supposed to?
