carb stuck closed!
carb stuck closed!
I'm in a bit of a tight spot... just noticed that my carb is stuck closed, i can't open it. I tried to open it by hand, pulled on it gently but it won't budge. it moves a couple of millimeters then stops, like its caught on something. I've even tried taking the low speed needle out before opening the carb but still nothing. any ideas? its an axial .28 carb btw...
