HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Engine dies at low RPM.
Old 10-12-2008, 08:07 PM
stevens4x
Default Engine dies at low RPM.
My truck (Savage X 4.6) dies everytime I let off of full throttle or when the RPMs get back close to idle. My idle is set right - wheels just barely don't spin when held off ground, although I can't test it now. The hsn is set good and I think the low speed is set good too. I have tried 3 new plugs. I don't have any fuel leaking from anywhere.
Also, I had been tinkering with the low speed. I set it to flush and have slowly leaned it. I am unable to find a spot where it will keep running. And I am using new fuel.
Any ideas?
Old 10-12-2008, 08:10 PM
GANGstar305
GANGstar305's Avatar
Default RE: Engine dies at low RPM.
tune it to factory settings and see what happens...
Old 10-12-2008, 08:25 PM
stevens4x
I have done that, several times. The problem is I still can't get to run at low speed. How do I know if its time to throw in the towel and try a new carb? Maybe I should try the engine seal fix.?.
Old 10-12-2008, 08:34 PM
GANGstar305
bbefore sealing your engine..check if your engine has any compression
Old 10-12-2008, 08:44 PM
Midget
 Midget's Avatar
Check The Clutch
Check the Glow Plug
Check the fuel lines
If they are all OK, Try Richen the Low speed out slowly...
Also, Have a watch of this...
[link=http://www.youtube.com/watch?v=BJFsJAxNoRg&feature=related]video[/link]
Old 10-14-2008, 04:10 PM
azzman
azzman's Avatar
Has the mid range needle wound itself to a new position?
Old 10-14-2008, 04:54 PM
CrysisFX
the x 4.6 has no mid range needle
Old 10-14-2008, 08:57 PM
3-172IN MTN
The SS model has the Mid range needle. If you have the f4.6 it does not have the Mid range needle. But both have a 4.6, just depends on if it is a K or an F that you have. SS vs RTR respectivel.
Old 10-15-2008, 12:47 AM
stevens4x
well I have been doind a rebuild and a little porting. Maybe the olf thich fuel I cleaned out of it will help. I magine it will run like crazy once I put it back in the monster.
I'll let you know how it turns out.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
