hpi savage FLUX....XL revealed
here is my hpi savage flux i bought two weeks ago. i just recieved it today in the mail from chris lugo hpi racing.i had to send it back to them cause it caught on fire the first time battery s was plugged in.defective esc,anyway hpi thought it was pretty neat.i still have yet to run it (just got home and found it on the porch) but by looking at it somebody had a little fun with it. thanks hpi team for the repairs and the extra goodies you sent me.
RE: hpi savage FLUX....XL revealed
Now all those mean nay-sayers are hiding with their tails between their legs haha! Nice! And to the haters, haha OWNED!
CA
ORIGINAL: Hordsak
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha he he he he he he he he he he he .i will say this with 25 43 gearing it is very very tight in the chassis.i will be testing it out this week and if all is well i will be building more if you know what i mean. next project is a 3 speed mod.
just a sidenote: multiple speed trannys have been experienced not to hold up very well in brushless trucks. it has been tested many times in revos, savages etc. the only way it seems works is with forkshifting 2speed trannys like in the e maxx etc.
bye
rhylsadar
ORIGINAL: rhylsadar
you got a 43T spur gear?
bye
rhylsadar
bye
rhylsadar
the "fork" is the part that shifts the gears inside the gearbox. so u shift the gear from 1st to 2nd with a servo.
normal nitro multiple speed trannys use a centrifugal clutch. and those work poorly due the enormous immediate torque of electric motors.
tekno rc offers a electric clutch for electric motors which eases the problem a bit. an additional brake servo and no reverse are additional disadvantages.
bye
rhylsadar
bye
rhylsadar
Watch those MaxAmps batteries....I have used those in my Heli's and they are prone to puffing !!! So don't run em below 3.2v or overcharge em or you'll be replacing em. You might want to check out Zippy lipo's from HobbyCity...they're a TON cheaper and are just as good as MaxAmps, FlightPower, any of em....I've been using em in my Heli's for quite some time with no issues!
yeah they puffed up today after about 25 min of running.i will check oout other soon thanks
thanks for tans info. i am going to give it a try,couple things will need to be changed inside trans,if it does not work i have another way to make it verible speed .
NY
ORIGINAL: ilikestuff_2
ORIGINAL: ArancioC5
you said you spent 200 bucks on the xl conversion from stock flux....................bro all you did was cut out the part of the chassis that I stated about a month ago. I could have done that too but guess what........ you just made the right side TVP weak. All you did was buy the Flux motor/ esc and hack up an XL. I am not knocking you, but that was never born a FLUX. Nice try though. Mine wasnt eigther so I am not knocking "building" however what you did is weaken an XL chassis, at least bolt on a support to the top of the right side TVP. As I said, I could have done this over a month ago but realized it was better to wait for HPI to do it. Not to mention the COG is a bit higher on the XL chassis.
Jealousy is a very bad quality...Just give it up to the guy about his build!!! lol
ORIGINAL: ezl_oo
NY
ORIGINAL: wingedwheel-0420
i wanan see the vid of it busting in half,cause you cut out a main piece of the tvp,lmao
Brent, tell me though, do you also make the Tarzan jungle call when you swing from people's "vines?" Stop living vicariously.
.....talk about sheer genius, i'll be right back guys I'm going to power sand my TVPs so they are 1mm thick so my Flux goes faster......I'll make sure I coin that conversion first!
The tvp can be braced very easily.
Also why would you want it to be born a flux? The xl parts are more common and are proven to be durable. Just give the guy his props. Yeah he made a mistake with the tvp but that is fixed very easily (see picture).
I drew the top view upside down. Flip it 180 and it's right. The brace would lap on the outside of the tvp leaving clearence for the motor.
TX
Arancios right. He didn't "build" anything, he cut out the part of the XL chassis that was in tghe way, weakening the chassis. Now its going to bend the first time he hits something at 50mph. I love the idea of an XL FLUX, but he went about it the completely wrong way.
NY
You can brace it........I posted that a long time ago also. The XL is just a TVP...it is not "proven strong." I had an XL, I have experience thanks. The brace however is still not 100% as strong as stock. Listen, you can chop the TVP till your blue in the face and I'll sit back untill HPI makes an extended chassis that is Flux based. One thing people forget to mention is WHY DIDNT HE JUST DRILL THE HOLES TO MOUNT THE STOCK BATTERY BOXES INSTEAD OF USING THE PLEXI? Maybe because the XL chassis has an ARCH so if you mount them low and bottom out you will DAMAGE YOUR BATTERY BOXES. There is a very good reason why I didnt modify the stock XL chassis when I was the very FIRST person to own OEM FLUX parts.
Give the guy credit for what exactly? A cut up, weakened(tvp AND batteries) Savage? Wow that pure genius. Again, I smelled a fraud from day 1 and thats what it still is. It would have been different if the guy just said he saw my posts and bought some flux parts like I did and mounted them to a base XL chassis.
I wouldnt care but when you post others read it and he was giving out false info. He lead people to believe that he had something people could/ should copy and all he has is a BAD design that was already warned about by me, but he did not listen and created something less then impressive. I state facts not opinion.
ORIGINAL: ArancioC5
Theres fixes for everything. You just have to know how to go about it.
So whats left? Weak battery boxes? Shouldn't be hard to figure out.
ORIGINAL: ArancioC5
lmao seriously, YES I AM VERY JEALOUS! So jealous I posted the info on how to do it um.... wow was it that long ago? I think I had the very first XL flux post on any forum and the first person to build one using stock parts in the world so yes, I am very very jealous.
