Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks > HPI Monster Truck Forum
Reload this Page >
New and Improved Super Heavy duity Ring and Pinion
HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Old 05-27-2009, 02:31 AM
jbooker82
Default New and Improved Super Heavy duity Ring and Pinion
Hay just to give you guys a head up HPI changed the Super HD ring and pinion. (IE Standard Flux gears). Where the bearing rides on the ring gear has been machined down so they can use a bigger ball bearing. The kit comes with the bigger bearing. I wonder if it is the same ones that are used for the pinion gear. The pinion fits right in it.
josh
http://www3.towerhobbies.com/cgi-bin...&I=LXWUZ7&P=OW
Old 05-27-2009, 03:32 AM
3-172IN MTN
Default RE: New and Improved Super Heavy duity Ring and Pinion
Wonder what a complete set will cost on eBay?
Old 05-27-2009, 06:00 AM
MGT
Funny this is just comming up now? My fluxcame withthe larger bearings and it still eats them. I blew the pinion and cracked the larger bearing in the first 2 min of my trucks life...It still sucks. I've blown 5 so far with like 6 packs through the truck.......My CEN diffs are going in now.
Old 05-27-2009, 08:36 AM
hghflyrjd1
Late. I've had mine in for 2 weeks. All the cups can also be used and they are also SUPER heavy duty
Old 05-27-2009, 03:14 PM
BANKRUPTER
I wonder if this will fail like it does on the cen diff.
Old 05-27-2009, 04:32 PM
dakamat
Have you ever fail a CEN diff??[X(]
Old 05-27-2009, 05:06 PM
BANKRUPTER
I stopped using them but have seen 4 go. that tube for the inner bearing race shears off. They also take out pinions like HPIs just not as easy. Fredj on HPISF just blew one in the front of his X braking hard to keep from hitting his kid the other day.
Old 05-27-2009, 05:20 PM
supertib
supertib's Avatar
ORIGINAL: BANKRUPTER
Braking hard definitely plays a huge role..... when you consider the amount of weight transfer directly onto the front end during braking its not hard to see why... A center diff or OWB would make a huge difference in saving the front diff during braking....
Old 05-27-2009, 11:33 PM
jbooker82
ORIGINAL: MGT
Funny this is just comming up now? My flux came with the larger bearings and it still eats them. I blew the pinion and cracked the larger bearing in the first 2 min of my trucks life...It still sucks. I've blown 5 so far with like 6 packs through the truck.......My CEN diffs are going in now.
So you have the larger bearing on the ring gear? When I first upgraded the rear of my savage to the flux gears it used the same thin bearing on the diff cup and the ring gear. The new Ring gear has been machined down so they can put a thicker bearing on.
I have never broken a gear. Usually the bearing on the ring gear goes out then that causes the mesh to be off and it just grinds the teeth down.
I will post some pics in a sec.
josh
Old 05-28-2009, 12:57 AM
jbooker82
Here is a pic of the gears and there bearings.
Old 05-28-2009, 08:37 AM
MGT
The ones on the right came in my flux stock...and one cracked the first 2 min i ran it.
Old 05-28-2009, 08:51 AM
jbooker82
I am glad I decided to leave the hpi bearings out and installed Boca green seals instead.
Old 05-28-2009, 01:19 PM
Sparkyf
Wish I would have known....Just recieved 2 of the 86922 hpi machined heavy duty ones today in the mail.....price diff is only 2 bucks, plus you get the new bearing with the super heavy duty.
Old 05-29-2009, 05:43 PM
Van Pelt
Van Pelt's Avatar
If you are handy with a lathe (or have a friend), then you can turn down the stock one.  Then you use a wheel bearing off of a savage.  My friend did this to his.  I plan to take apart all my junk and get him to do the same to mine.
Jon.
Old 05-29-2009, 06:22 PM
BANKRUPTER
Good idea jon!
Old 05-29-2009, 10:11 PM
whipnet
whipnet's Avatar
Man Bank, you're really on a anti-CEN campain aren't ya? hee-hee
Still loving mine....
Old 05-30-2009, 11:41 AM
BANKRUPTER
I am now yes Whip. Would not have sold them if I was in the middle of the road with them...
Old 05-30-2009, 08:21 PM
MGT
I don't get it....The 'new' diffs came on my truck stock and I bought it months ago????? Anyone else care to chime in here...I think they still stink..
Old 05-30-2009, 10:50 PM
hghflyrjd1
Yes stock flux gears. U said u think they still stink. Y is that. What are u breaking and from what type of driveing did u shime them. Imm just teying to find out if there worth the upgrade. People have been droping them in the X,XL. I have the flux diffs in mine but my brother inlaw has the stock stuff and today he blew something in the rear just from ripin up the street with street tires no jumps. We didn't open it yet but I bet its from bad stock shiming. I added 2 to mine when I upgraded to flux to keep it all tight. But I don't know how much stronger these "super" heavy duty gears are gonna REALLY be.
Old 05-31-2009, 05:26 PM
jbooker82
Yea the shimming of the gears has a big part in how long they last. Just like shimming the Spur gear.
I would also thow some boca bearings in the diffs instead of the HPI bearings. Usually when I have a diff go out it is from having the bearing come appart then that lets the ring gear move and grind the teeth off.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
