Just got a savage x
IA
Just got a savage x
Hey everybody i'm new to the savage forums, i finally gave up and sold my warhead to get a savage. But my question is, what gearing would you guys reccomend? I was looking at the robinson racing 16/ 48 setup because i figured that would be a good all around setup and it's a good excuse to upgrade to a steel spur gear. Your thoughts?
My Feedback: (10)
IL
RE: Just got a savage x
I would personally do either 16/47 or 17/48.....I think those would be about the same, no? I like a little more top end on my trucks. Both of my trucks wheelie very easily with 16/47 gearing. XL has LRP30 and X has stock F4.6
VT
http://www.rcuniverse.com/forum/m_84...tm.htm#8431836
metal v plastic spur thread,
i run a k4.6 in my X, with Al shoes 17/47 can pull wheelies not at the touch of a trigger but doesn't labor to do so either
the lug
the lug
IA
Hey guys thanks for your help, i ended up going with 16/48. It has a good balance between low end and high end and is still a wheelie monster
KS
If you decide you want to run bigger tires or a little more speed, you now have a base to work with. 16/48 is a 3.0 gear ratio. Just divide the bell into the spur. So to go faster a 16/47 would give you 2.93, not a big step, but one you would defintely notice or 17/47 a 2.76 gear. Same thing the other way, if you wanted more power for a larger tire or to run in soft sand, 16/52 would give you a 3.25 ratio. The numbers are kind of confusing. In this case the larger ratio number is actually the lower gear or more power. The 3.25 for example is 3.25 engine revolutions for every one revolution of the transmission input shaft. The stock gear for a XL with the 7" tall Terra Pins is 16/52 or 3.25. Glen
TX
I run 20/47 with a moderatly ported stock motor and the wheelies still creep up when I floor it...Oh, I'm using the HD Steel Spur gear and the Vented racing bell, both from HPI.
KS
ORIGINAL: MadManAndrew
TX
I'v got the HPI Aluminum shoes with, as I said, a vented Racing bell, and I switch between the stock GT2 tires and REVO tires...And, yes, it's the F4.6. I've also got the Racing Suspension kit from HPI, so the suspension geometry is alittle different.
KS
Normally what happens when guys start to push the upper gear ratios is that they smoke the clutches trying to run anyplace that is not hard packed. The short tires are helping you out a lot, but I suspect you do not climb many soft dirt hills or run in deep grass surfaces. The load becomes more than the clutch can handle.
TX
ORIGINAL: BudBud
