Flux battery Minimum Amp question
Like everyone after puffing out a battery, learning what actually means what and does what seems so much more important.
I read that the minimum amp for Flux's should be 120-125amp. But I see everyone on here including myself using hobbyking Turnigys rated 5200mah 2S 20C.... now the math on that is: 5200 x 20c / 1000 = 104amp So at least 16-21amp below the minimum recommended. So is it unsafe to use these batteries then? Is that "close" enough? Or....? I never see high mAh capacity Turnigys with 25C or greater sold on Hobbyking... 20C seems to be the norm. Explanation? |
RE: Flux battery Minimum Amp question
http://hobbyking.com/hobbyking/store...dProduct=14991
there 30-40C :P ones I use with my savage with a 150A ESC/motor combo, and on my truggy with the CC MM 2200kv combo in it as I put in your other thread your batteries mainly puffed due to storage, and if they were 20C yes you probably taxed them too much specially after they were damaged. |
ORIGINAL: SyCo_VeNoM http://hobbyking.com/hobbyking/store...dProduct=14991 there 30-40C :P ones I use with my savage with a 150A ESC/motor combo, and on my truggy with the CC MM 2200kv combo in it as I put in your other thread your batteries mainly puffed due to storage, and if they were 20C yes you probably taxed them too much specially after they were damaged. |
Without onboard AMP meter there is no way to know the load while the truck is running, all you can do is monitor ESC and Motor temps to guess at the load. So yes a 20c Pack is a little light for 1/8 scale Truck on off road conditions, lowering your pinion would give a little headroom for Amperes if you already own the 20c's.
I shoot for 135 F on both Motor and ESC under heavy load for several minutes to ensure my batts will survive, WOT runs again and again for long distances give a good test for batts and Pinion combination. High quality batts can take abuse far better but I opt for thoses chinese noc-offs and am having great success at 50% savings in cost. |
ORIGINAL: jjonesfla Without onboard AMP meter there is no way to know the load while the truck is running, all you can do is monitor ESC and Motor temps to guess at the load. So yes a 20c Pack is a little light for 1/8 scale Truck on off road conditions, lowering your pinion would give a little headroom for Amperes if you already own the 20c's. I shoot for 135 F on both Motor and ESC under heavy load for several minutes to ensure my batts will survive, WOT runs again and again for long distances give a good test for batts and Pinion combination. High quality batts can take abuse far better but I opt for thoses chinese noc-offs and am having great success at 50% savings in cost. For example if a battery is rated 160Amps if a MM(what is in the savage flux its rated 120A) pulls 130A's continually either the motor or esc will burn out. Its when you cut it close that there could be that room where the batteries might not be good enough. |
