wheels not responding to remote
has anyone had a problem with their savage 25's wheels not responding to remote? when i turn on my receiver wheels stay in a normal straight ahead position. but once the radio is turned on the wheels turn to the right and stay in that position. i've tried adjusting the trim but it does not help. any ideas or suggestions on what the problem may be?
RE: wheels not responding to remote
try adjusting you servo horn, or servo saver.
diconnect the servo saver & see if the servo turns to the right & left without the servo saver hooked to it.Ift the servo works properly then center you steering trim & reattach the servo saver so wheels are as close to straight as possible then try steering again.All should be well.if wheels are off slightly either use the trim or adjust the steering rods so wheels are straight.
