RCU Forums
-   HPI Monster Truck Forum (https://www.rcuniverse.com/forum/hpi-monster-truck-forum-250/)
-   -   2 diff ??? (https://www.rcuniverse.com/forum/hpi-monster-truck-forum-250/4245724-2-diff.html)
myber92fs 05-06-2006 12:34 AM
2 diff ???
1 Attachment(s)
on average how often do you have too rebuild your diffs with the 4 spider gears??? Also do you know what size shims I need for the bevel gear like this
savageman90 05-06-2006 09:12 AM
RE: 2 diff ???
i usually rebuild my diffs once a year, unless i break a diff
RCaeroguy 05-06-2006 08:29 PM
RE: 2 diff ???
I'd agree with that. I do it once a year unless things go wrong.
poe 05-06-2006 08:32 PM
RE: 2 diff ???
what the hell is a shim/shimming im sorry i ask such nooby questions, but what can i say
myber92fs 05-07-2006 09:14 AM
RE: 2 diff ???
No one know what size shims I need??
alvinl 05-07-2006 09:31 AM
RE: 2 diff ???
I have seen it posted here somewhere, but I myself to not know. If there is a hobby shop close to you, give them a call and see if they have them. They should be pretty cheap.
blindguy 05-07-2006 10:02 AM
RE: 2 diff ???
You need 8mm I.D. shims for the pinion gear.
myber92fs 05-07-2006 11:00 PM
RE: 2 diff ???
Thank you !!! My LHS guys are not very helpful. I pretty much just need too know what I need and then buy it. They either dont know the little things about the savage or just dont care to share there knowledge. Im not too sure witch it is but it stinks. There is only one real HS in town and it seems like they dont give customer service cause they dont have any competition. Wish I had the $$$ to open my own lhs I could make a killing w/ good service!!!
46u 05-07-2006 11:37 PM
RE: 2 diff ???
The LHS hear is going out of business do to the poor service they offered. With so much availability on line shops better look out. The only thing I got from them was fuel and now I am going to have to order it. I have been told there is a new shop opening and they are going to have a track. Just have to wait and see but I sure hope so. Hope they are better then the last one. :D
Jeht Black1 05-09-2006 12:42 AM
RE: 2 diff ???
as far as diffs go, is the front set-up like the rear? is the a 4 bevel gear set and diff housing different than the rear
boydie1 05-09-2006 05:58 AM
RE: 2 diff ???
The front and rear diffs are the same. Many people add different weight lube front and rear though
