Stop Go Stop Go
My savage XL was running fine so I decided to get the transmission set because it was only shifting once, now when i run it it goes for a while then it stops then it goes then it stops. Does anyone know whats going on?
RE: Stop Go Stop Go
How does it do this? Does the engine go crazy or does it seem like something is holding the truck back? Try going back to stock settings for the transmission and make sure nothing is binding in the gearing or anywhere in the drive-train.
RE: Stop Go Stop Go
I can hold it full throttle and it will start to go then stop for a while then start to go for a while then stop again, Ill check the tranny again and do a reset.
RE: Stop Go Stop Go
Is your tune decent with no air-leaks?
RE: Stop Go Stop Go
Did you tighten the nut on your slipper clutch?
RE: Stop Go Stop Go
Found out what the problem is, my receiver or radio is bad so when I would press on the gas the failsafe would kick in. I took out the failsafe and now nothing works, so I ordered a 3PM Fasst to replace the stock one.
RE: Stop Go Stop Go
Well aren't you glad you had the fail safe!
RE: Stop Go Stop Go
Had the same problem long time ago. It was my crystals on the stock radio. I changed out to a different channel and the problem went away.
Also, make sure that the crystal is all the way in the receiver. |
RE: Stop Go Stop Go
My crystals shook to bits in my XL before i packed it with foam to stop the vibration. Try this with a new rx crystal before your Fasst turns up if you wanna bash before then.;)
