problems with trans?
TX
Ok my problem is I tried to use my afpd the other day and when I started the program and went to fly the plane I had no control of the plane all control surfaces were doing what ever they wanted to do so I tried to re-calibrate the controler by the way I am using a futaba 8u and when I went to the calibrate screen the number of channels detected was bouncing from 24 to 12 to 8 to 4 back to 12 you get the idea if I took and moved the interface cable around things really went crazy the area of the cable I was moving was where the 2 trans. plugs are. anybody have any ideas?
