Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
AeroFly Pro vs. AeroFly Pro Deluxe
Old 08-30-2006, 07:52 PM
NightOne
Default AeroFly Pro vs. AeroFly Pro Deluxe
I'm sure this has been covered before, but I damn if I can find it.
Can someone cover the specific differences between these two?
Old 08-31-2006, 12:57 PM
Greg.B
Default RE: AeroFly Pro vs. AeroFly Pro Deluxe
Hi,
Here's basically what AFPD has over AFP:
Aircraft:
[*]Highly detailed new models, which are not available for AFP. [*]Flight physics reworked. [*]Light weight aircraft (shockflyers etc) and helicopters (piccolo) now work correctly. [*]Left turning rotor systems for helicopters added. [*]More than 4 rotor blades supported. [*]Dual head helicopters supported. [*]Smoke is now supported for 2 models. [*]Model surface reflections can be switched on/off. [*]Easyfly models are now supported in AFPD. [*]Glider sound added. [*]New free patch to add VPP (Variable Pitch Prop) feature and a new Edge 540 Shockflyer for it.
Sceneries:
[*]New 3D sceneries. [*]New panorama scenery function has been added (it has to be one of the most noticeable differences). [*]Rotating objects are possible like wind turbines (3D sceneries). [*]Transparent water surface (3D sceneries). [*]Moving clouds (3D sceneries). [*]Fog can be set from 0-100%. [*]Background music can be switched on/off.
General:
[*]Large preview image and preview text added to model selection menu. [*]Help text added to main menu. [*]USB cable instead of serial cable. [*]USB cable adds transmitter to windows game devices, so it can be used for other games. [*]Improved interface for easy/advanced transmitter setup. [*]F11 key for high quality screenshots, number not limited.
That's most of the main differences.
In additon there's an Add-on for AFPD which makes it even better!
Here's a list of aircraft, scenery and features on the Add-on:
New Aircraft:
[*]Augusta 109 [*]Aztec [*]DC-3 [*]Diamond DA-40 [*]Diamond DA-42 [*]Super Constellation [*]Viper 90 [*]Zero [*]Monsoon [*]Monsoon-4D (with PPS-4D system) [*]SlowRide [*]SlowRide-4D (with PPS-4D system)
Scenery:
[*]Photo-scenery Omahawks (beautiful field in the USA with a long asphalt runway) [*]Photo-scenery TheField (a fairly big field in the USA with a big grassy runway) [*]Photo-scenery PageField (Airport located in Florida, USA) [*]Photo-scenery Neuenbuerg (Gymnast hall of the town Neuenbürg in Germany) [*]3D-scenery MountLake [*]3D-scenery EggeLand
Other Features:
[*]Updates AFPD to version 1.9.1.3.[*]Support for up to 4 smoke emitters on aircraft.
If you have the Add-on there are some additional aircraft and scenery you can download in the members area also.
There is then the latest patch (1.9.5.7) which includes a few more features:
[*]A new air-race contest.[*]Wind direction, strength and turbulence can now be changed using keys ‘1’ to ‘6’ [*]The variometer is showing a green colour, when a glider gains energy (e.g. when you are flying in thermals) and showing in red if the glider is loosing energy (e.g. in a downwind area) [*]The rope length in Glider Tow mode can now be changed in the Glider tow menu during simulation
Hope this helps.
Greg.
Old 09-03-2006, 09:06 AM
Littlebrain
Banned
Hello Greg,
since you are an expert in AFPD, could you modify a 3D plane making chord at tip longer than chord at root?
How does the plane fly? Better?
Thanks a lot.
Littlebrain
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
