Bad USB Cord?
#53
Moderator
My Feedback: (58)
Rich, I would recommend that you use the 9C as you could use all the computer mixing features. What you need to get are:
1) An usb slave cable http://www.ikarus-modellbau.de/onlin...08251.38233896 You will need to plug this into a free usb port. The game commander will still need to be plugged into another usb port as it contains the software key
2) A Futaba square adapter. You could get http://www.ikarus-modellbau.de/onlin...ca088.63839801 or http://www.fxaeromodels.com/product_...oducts_id=1658
Switch off the 9C. When you plug in the adapter, the 9C will automatically power on and the RF circuit will be disabled.
#55
Good Day, Excuse me for my english.
I have a problem with my Aerofly Professional Deluxe 1.8.0.9. when i start it says is unable to locate the interface cable and asks to to plug it. i dont have any cable, i want to play it in my computer, someome told me there is a file that i must replace in the main folder and will work perfectly. can you please tell me where to find that file or if you have it send it to me, thanks a lot. [email protected]
#56
My Feedback: (42)
I got my3036+002 slave cable today and cannot seem to set it up to fly my T9CAP Futaba. Also got the MX22/JR/Fut adapter (31036)
I went throug it at the website and even downloaded the 1.8.0 25 patch and recycled the computer.
What am I doing wrong? When I try to calibrate the dummy interface the channels freak out and it says it is finding transmitter with 6 then 23 channels and won't let me calibrate.
Help!!
Richard
Help!!
Richard
#60
My Feedback: (42)
Did you set the 9C to PPM mode? That did the trick!!
Did your GC worked with your PC setup previously? Yes
BTW, do you have any addons? Not that I am aware of.
Question, is it better to set my expo's on my transmitter or in the program?
Thanks for the help.
Richard
Richard
#64
Moderator
My Feedback: (58)
Mauritz, if you have installed AFPD add-on 1 and/or Starflight add-on, then please download and install patch 1.9.7.11 http://www.aerofly.com/www/downloads.html If you do not have any add-on, please download and install 1.8.0.25
