RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   Aurora 9 andAF5 (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/10267218-aurora-9-andaf5.html)
Ernies 01-16-2011 07:39 AM
Aurora 9 andAF5
Are any adapter cables needed with Hitec Aurora 9. Will same cable for other Hitec work.
rajul 01-16-2011 07:43 AM
RE: Aurora 9 andAF5
Hi Ernies, I do not have an A9 to test but the following info was from other users:
Create an ACRO model in the A9, remove the module, power it up (it doesn't power up automatically with the trainer port plugged in), plug the usb cable in (no adapter needed) and calibrate in AFPD.
Ernies 01-16-2011 07:53 AM
RE: Aurora 9 andAF5
Do you mean in AF5
I have a imac 27" I5 with 4850 and 512
thanks for the response will order a AF5.
rajul 01-16-2011 07:59 AM
RE: Aurora 9 andAF5
It should be the same in AFPD or AF5. I would suggest that you contact Hitec and also check with them on the A9 compatibility with flight simulators. Please also check the system and video card requirements for AF5 http://www.aerofly.com/requirements_en.html
Ernies 01-16-2011 08:35 AM
RE: Aurora 9 andAF5
emailed ikarus and ikarus usa last week and attempted to call, no response from them. I checked requirements, I should be ok on them.
Thanks for your reply. At least I have a better idea. I also emailed OMP maybe they will know.
