AFPD Interface Cable Shorting Out
Rajul,
My AFPD interface cable has developed a short in the end with the phono plug. I'm currently using it with an Aurora 9 transmitter. It works fine as long as don't jiggle it while I flying. Is there any way I fix or replace it? Jeff.... |
RE: AFPD Interface Cable Shorting Out
Hi Jeff, how did you confirm the short? Could you post a photo of your cable? Thanks
Rajul,
Wanted to post pick of cable but it keep coming out blurred. Do you have any pics of where wires on plug going into the transmitter are supposed to be soldered I could try and copy? Jeff |
1 Attachment(s)
Here's a pic of the internal soldering connection. I recommend an additional soldering between the post and the lug as shown to prevent intermittent connection.
Rajul,
Thanks for the pic. I tried to solder the plug as shown and no luck. I noticed the Aerofly website sells a slave interface cable with plug in thumb drive for $34.95? Would this work on my Aerofly 1.8.0.17 edition if I buy it ? Also, if I do purchase it would I need to buy anything else in addition to the cable? Jeff....... |
Jeff, how old is your AFPD since you purchased it? Please post a photo of your usb cable so that I can tell which version it is. Are you getting any error messages in AFPD?
1 Attachment(s)
Rajul,
The version of AFPD I'm using is 1.8.0.17 and I'm not getting any error messages? Whats happening is my stick inputs have little or intermittent effect on the models. I re soldered the plug per you photo but still no luck. I would love to send you pic of cable but I cant get them to upload correctly to RCU. I upload pics all the time using my regular email with no problems. Am I missing something here? Jeff..... |
1 Attachment(s)
Here the rest of the pics I think?
[img][/img][img] |
Jeff, your usb interface is a very old design and is most likely outside the 2-year warranty. I would suggest that you purchase a replacement usb cable from Ikarus USA. The replacement cable will be of the latest "usb key" design, and you will be able to use it when you choose to upgrade to AF5.
The old usb interface cable has to be returned to Ikarus USA. The cable will be exchanged for $29.95 plus S&H 8.95. Call Frank. IKARUS-USA, Service Department 1136 NE Pine Island Road, Unit 83 Cape Coral, FL 33909 Phone: 877-550-AERO (2376) |
Rajul,
Thanks for the information I will contact "Frank" at Ikarus on Monday..... Jeff.... |
Most welcomed. Let me know if you need anything else.
| All times are GMT -8. The time now is 05:31 AM. |
