Want to go wireless
I currently have an older USB connector afpd that has a jack on the end. I upgraded to afp5 last year.
The original cable shorted out and they replaced it about a year ago. Now I would like to go wireless. I own both version so to go wireless does that require buying an entire sim again, or can I upgrade to the USB wireless setup to use on the two versions I already own? Thank you, gordon |
RE: Want to go wireless
Hi Gordon, what type of transmitter do you plan to use? Is it a FM/PCM or 2.4GHz radio?
Futaba 14MZ 2.4
Gordon, you could use the Ikarus Single Line converter. You could get some information about the SLC here http://shop.ikarus-usa.com/accessori...ine-converter/
But will that work with the old style cord?
No, it will not work with the old style cord. How old is the cord?
On the single line converter does one have to use male to male connectors not the standard extension that is male/female? It appears to me but you do not specify on the website.
The SLC comes with all the necessary male-male connectors.
