RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   QUESTION ON SMOKE USING ECLIPSE (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/2500106-question-smoke-using-eclipse.html)
BAS 01-04-2005 06:20 AM
i have a eclipse radio i usually use the channel 5 retract gear switch for activation of the smoke and to control the smoke going on and off. On my aeroflypro i need to know how to set the radio up to being able to use the channel 5 retract switch to do this with the smoke. Or if there is another way to activate the smoke off and on i am would like to know. Bruce
STLPilot 01-04-2005 07:10 AM
RE: QUESTION ON SMOKE USING ECLIPSE
You can assign a keypad button to the smoke if you are out of switches.
