new patch
Im a little bit p.......d of
new patch 1.8.0.17 has totally messed up my aerofly pro delux it will run in small window. When i go into options to set resolution to 1080 x 1024 i get error report message. I have restored my computer to a few days earlyer when it was running great and now its still the same as above[&o] |
RE: new patch
Right
done a complete reinstal all working ok now somtimes i wonder where these gremlins come from.:D |
RE: new patch
When you install the patch it's going to set to default window mode.
You may want to check your screen settings and make sure you resoultion matches the same resolution you want to run AFPD in. |
RE: new patch
THANKS STLPILOT
I Will note that down for next time it happens.:D |
RE: new patch
This new update is very buggy!!!
There is now a shadow in front of the plane, and in Helicopter simulation it freezes up. I have to kill the task in windows manager. I reloaded with the old patch, and the problems went away. Put the new upgrade patch on and it has the same bugs. Helicopters don't work correctly anyway, but at least it did not kill the program STL pilot, please do not tell me I am doing something wrong, the new patch is buggy. I am just trying to help. BR, MarkC |
RE: new patch
I'll let em know ... I've seen no bugs on it.
Thanks |
| All times are GMT -8. The time now is 07:10 PM. |
