Help Me Dion!
I am TRYING to use a Tower Hobbies 6FM radio with AFPD and it won't work. I turn the radio on, start up AFP, then go into calibrate, and select the radio, and it says "No Transmitter Signal detected" How do i get it to work? i tried with the crystal in and out, should i take the antennae out?
Please Dion, HELP! lol Thanks, Scott |
RE: Help Me Dion!
Is this the only radio your having a problem with?
Does it work for other radios? |
RE: Help Me Dion!
the only other radio i have is the EXA with the micro plug, so i haven't tried it yet.
RE: Help Me Dion!
So was it working before and now you lost it?
RE: Help Me Dion!
I sometimes use a Futaba 6 NFK. I think it is the same radio as your Tower. I have to turn the power switch on. I also use a Futaba Super 8 and it does not need the switch on. I also take the Xtal out of the 6 NFK, the batteries last a lot longer that way.
Ron |
RE: Help Me Dion!
i just started trying to use it, can't get it to work
| All times are GMT -8. The time now is 08:04 AM. |
