New video tutorial for installing AFP(D) aircraft
For anyone wanting to learn how to install an aircraft for AFP or AFPD here ya go!
I'll probably make some more tutorials for FAQ's. I hope this helps a lot of you guys that are having problems installing the aircraft. Enjoy! [link=http://www.flybuder.com/aeroflyvids/install/index.htm]Click here to view the Flash tutorial[/link] |
RE: New video tutorial for installing AFP(D) aircraft
nice work should save you answering that question 8 million times more LOL
Thanks!
You have no idea how many takes I had to do. I thought leaving a message on my answering machine was difficult. This is 10x worst. If you can think of any more instruction videos to make let me know and I'll create them. |
what did you use to make that? i would like to try it for my VTOC recording
Sorry, it won't work for VTOC.
hrm, if you don't install the sound will the aircraft not work?
also note: winrar is not registred on your comp... :) |
darn
flash MX or flash corperate im guessing. nice bit of work dion
The flash tutorial is great, but it didn't work for me installing planes to aerofly pro. Do the planes work on deluxe only or did I do something wrong, I think I did everything exactly as described.
Thanks Lee |
I discovered the problem with my AFP not recognizing dl planes was that I had to install the patch to update AFP. The planes work fine now.
Is it easy to burn this tutorial vidio on a floppy disc or compac disc...so I can paly it about 100 times!! Thanks
How do you save the file to a disk"
Sorry ... you can't it's Flash. Just use the pause feature.
It should only take you 1 or 2 times until you can do it on your own. |
Thanks for quick response to my question!
will this work the same if i was using the reflex XTR sim.
thx, shawn |
How about a radio calibration tutorial? .. Ive spent an hour on this and I cant get my Futaba 6exa working right. The slightest touch of any controll max's out the jittry calibration bar. Have reset the radio to factory defaults. All trims set to +/- 0. Not sure what PPM mode is, but the manual here has no relevance regarding it (hit cntrl+f to search pdf contents) http://www.futaba-rc.com/manuals/6exa-manual-v1_1.pdf
Dont know what else to do. Cant get AFPD settings zero'd out. /sigh |
Are all your channel jittery or just a couple?
Hey STL when I clic to veiw it shows the OMP on the bottom of the page but I see nothing in the box
When I try to go to the flash tutorial I get:
"You don't have permission to access /aeroflyvids/install/index.htm on this server." What is wrong?? Flierbk |
I get the same error too... whats going on ?
Brian |
Forbidden here ?????? [X(]
By the way Dion , can you make also a tutorial for scenerys? So many questions from people about that..... Thanks in advance [sm=thumbup.gif] |
Tutorial still doesn't open. Any chance that's going to be fixed?
The flybuder thing does not work. The site is down or something. anyone who knows how to install downloaded aircraft please help. I unxzipped the single .zip file and copied the files into a new directory under ./aircraft in the aerofly program directory, but it does not show up. I do _not_ want to use a 3rd party program to do this. I want to know how it is done manually.
Thanks! |
I have tried to view this tutorial, but get a "Page not available" flag. Any suggestions?
Thanks. Arniebud |
I found out a key piece of info: the .bmp and the .tmd names must be the same. Once I did that, my downloded aircraft showed up.
| All times are GMT -8. The time now is 12:58 PM. |
