How to - Flaps?
I've been lurking these sim forums since early Dec or so. Consensus led me to AFPD and I'm thoroughly pleased. Very trick program. I had zero problems loading or it recognizing my Futaba T6EXA. A bare minimum 64MB DDR NVIDIA GeForce4 MX420 gives me 60/70 FPS.
Most of you guys apparently are experienced hot doggers. I pretty much prefer slow, low and scale, and lots of landings. So far that is, because I've only got a couple gallons of fuel into an LT40. I got this sim to help better connect my brain to my fingers, and it's working. Very cool. I don't "stay away" from the "boring" trainers as suggested, and, I'm getting a Sundancer ready for spring, so I've been messing with both the Stearmans a lot. Don't know how close they are, but it's tons of fun. Anyway, in the real world I rigged my LT40 with Flaps, flaperons actually. In AFPD I can't get anything but opposing throws through the flap channel for the Trainer60 (and Stearman.) It's just duplicating my normal aileron channel. Reversing one "flap" doesn't "reverse" it either. Am I SOL or dumb as to how to do it? Joel PS For the guys that want them, the "Trainer60" does tip stalls big time, but it sure doesn't fly like a Pitts :-) |
RE: How to - Flaps?
Hello,
From the main menu, navigate to the calibrate section. Then you must choose the "advanced" settings. Set the left aileron on channel 6. |
RE: How to - Flaps?
Do what crowfly just said to do. AFP will never let you down, it has many more "can do's" then "can't do's".
Just like in real RC plane you must assign 2 channels to the ailerons. :D |
RE: How to - Flaps?
Duh! Wasn't thinking - (not rare.)
Thanks |
| All times are GMT -8. The time now is 09:24 PM. |
