Chip Hyde Ultimate problem
Everytime I try to run the spot-landing contest with the Chip Hyde Ultimate I get disqualified before it starts. Any suggestions? Thanks!
RE: Chip Hyde Ultimate problem
hi mayflyer
you press enter you will see a count down time on the sceen you have to wait for timer to finish it will then say ready then go. hope this helps regards Dave.:):) |
My chip bipe idles so rough I red light at the starting line. Chop the throttle trim & kill the motor 'till it's time to go. When it's time to go, stab the throttle & engine will start. set the trim back later. Crowfly
Copied from the Support Forum Guidelines:
If you want to hear opinions from fellow RCU members post it in the proper discussion forum. If you have a question, need help with a part or problem and need to talk to a company representative, this is the place. If you are a member and have answers to a question being ask in the support forums, send the person an email or private message. If you are a support forum host or company representative, keep the information to support related topics only. Please refrain from promotional material as defined in the Community Policies Post are subject to removal if they do not meet guideline and policy requirements. |
I disagree. This way other users can benefit from the response.
But it's not my web site. -Andrew |
Poor PR sheriff. You should have included from the guidelines (that I hadn't read - oops) "Support forums work a little differently in that the question being asked is only answered by a representative of the company, not other members." That's a little easier to swallow for some reason.
Joel |
| All times are GMT -8. The time now is 09:09 AM. |
