RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   throttle help (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/2687750-throttle-help.html)
Rich28 02-22-2005 03:03 PM
throttle help
Hi
I have just received AFPD and its awesome!!!
The only problem I have is with the throttle. When i throttle right back the engine idles, but 1 click up and the plane goes vertical. theres nothing in between. it makes it real hard to hover. Is there something I can change or is it just me and I need to get used to it
-Richard
STLPilot 02-22-2005 04:55 PM
RE: throttle help
Have you calibrated it per the instructions.
Also when it says put sticks at neutral that means in the middle, not bottom.
Rich28 02-22-2005 10:08 PM
RE: throttle help
I didnt put the stick in the center like you said
Thanks a lot
-Richard
