RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   cant find usb error (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/2743096-cant-find-usb-error.html)
pezzheaddazzler 03-08-2005 08:34 PM
cant find usb error
[&o]
its been 2almotst 2 weeks and i still havent got it running
here are my system settings and tm.logfile
1.1.0.17
OS Name Microsoft Windows XP Home Edition
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Manufacturer System Manufacturer
System Model Product Name
System Type X86-based PC
Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2200 Mhz
BIOS Version/Date Phoenix Technologies, LTD SAP41, 7/22/2003
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version
Total Physical Memory 256.00 MB
Available Physical Memory 54.29 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 568.63 MB
Page File C:\pagefile.sys
Name Realtek AC'97 Audio
Manufacturer Realtek
SiS 7001 PCI to USB Open Host Controller PCI\VEN_1039&DEV_7001&SUBSYS_90651509&REV_0F\3&61A AA01&0&18
SiS 7001 PCI to USB Open Host Controller PCI\VEN_1039&DEV_7001&SUBSYS_90651509&REV_0F\3&61A AA01&0&19
SiS PCI to USB Enhanced Host Controller PCI\VEN_1039&DEV_7002&SUBSYS_90651509&REV_00\3&61A AA01&0&1A
USB Root Hub USB\ROOT_HUB\4&2203C237&0
USB Root Hub USB\ROOT_HUB\4&34BD72DC&0
USB Root Hub USB\ROOT_HUB20\4&17ABC47E&0
MEMORY
0xFFFF0000-0xFFFFFFFF System board OK
0x0000-0x9FFFF System board OK
0xFFEE0000-0xFFEFFFFF System board OK
0xFFFE0000-0xFFFEFFFF System board OK
0xFEC00000-0xFECFFFFF System board OK
0xFEE00000-0xFEEFFFFF System board OK
0xE4000000-0xE5FFFFFF SiS Accelerated Graphics Port OK
0xE4000000-0xE5FFFFFF NVIDIA GeForce FX 5500 OK
0xD0000000-0xDFFFFFFF SiS Accelerated Graphics Port OK
0xD0000000-0xDFFFFFFF NVIDIA GeForce FX 5500 OK
0xE0000000-0xE3FFFFFF SiS Accelerated Graphics Port OK
0xE7003000-0xE7003FFF SiS 7001 PCI to USB Open Host Controller OK
0xE7000000-0xE7000FFF SiS 7001 PCI to USB Open Host Controller OK
0xE7001000-0xE7001FFF SiS PCI to USB Enhanced Host Controller OK
0xE7002000-0xE7002FFF SiS 900-Based PCI Fast Ethernet Adapter OK
0xE7004000-0xE70040FF Lucent Win Modem OK
0xA0000-0xBFFFF PCI bus OK
0xA0000-0xBFFFF SiS Accelerated Graphics Port OK
0xA0000-0xBFFFF NVIDIA GeForce FX 5500 OK
0xCF800-0xCFFFF System board OK
0xF0000-0xF7FFF System board OK
0xF8000-0xFBFFF System board OK
0xFC000-0xFFFFF System board OK
0x100000-0xFFEFFFF System board OK
0xFFF0000-0xFFFFFFF System board OK
0x10000000-0xFEBFFFFF PCI bus OK
TMLOG
tm: Library Version 4.1, Copyright (C) 1999-2004, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 1198428782
tmsystem: cpu type=(nlogical=1) (nphysical=1) (hyper-threading disabled)
tmsystem: cpu=2199 Mhz
tmsystem: memory=(physical=255MB, avail=120MB) (virtual=2047MB, avail=1876MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
tmgl: loading font v2 texture/arial10.tmf=(256x256) (32x255) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.8.0.17, Copyright © 1998-2005 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
afdesign: init ok
tmgl: loading font v2 texture/menufont.tmf=(512x512) (32x255) ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=800x600) (screen=800x600) (32bpp) (60Hz) (window)
directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 100,48000) (17 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=NVIDIA Corporation, renderer=GeForce FX 5500/AGP/SSE2, version=1.5.2
gl: (viewport=4096x4096) (texturesize=4096) (stencil=8)
gl: extensions=GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_HP_occlusion_test GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
wgl: extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_EXT_extensions_string WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (paletted texture) (separate color) (anisotropic filter of 8.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
gl: reducing max texture size from 4096 to 2048
tmsystem: fullscreen modes=(640x480x16x60) (rj-640x480x16x70) (rj-640x480x16x72) (rj-640x480x16x75) (rj-640x480x16x85) (rj-640x480x16x100) (rj-640x480x16x120) (rj-640x480x16x140) (rj-640x480x16x144) (rj-640x480x16x150) (rj-640x480x16x170) (rj-640x480x16x200) (rj-640x480x16x240) (rj-720x480x16x60) (rj-720x576x16x60) (800x600x16x60) (rj-800x600x16x70) (rj-800x600x16x72) (rj-800x600x16x75) (rj-800x600x16x85) (rj-800x600x16x100) (rj-800x600x16x120) (rj-800x600x16x140) (rj-800x600x16x144) (rj-800x600x16x150) (rj-800x600x16x170) (rj-800x600x16x200) (rj-800x600x16x240) (rj-848x480x16x60) (rj-848x480x16x70) (rj-848x480x16x72) (rj-848x480x16x75) (rj-848x480x16x85) (rj-848x480x16x100) (rj-848x480x16x120) (rj-848x480x16x140) (rj-848x480x16x144) (rj-848x480x16x150) (rj-848x480x16x170) (rj-848x480x16x200) (rj-848x480x16x240) (rj-960x600x16x60) (rj-960x600x16x70) (rj-960x600x16x72) (rj-960x600x16x75) (rj-960x600x16x85) (rj-960x600x16x100) (rj-960x600x16x120) (rj-960x600x16x140) (rj-960x600x16x144) (rj-960x600x16x150) (rj-960x600x16x170) (rj-960x600x16x200) (rj-960x600x16x240) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x72) (rj-1024x768x16x75) (rj-1024x768x16x85) (rj-1024x768x16x100) (rj-1024x768x16x120) (rj-1024x768x16x140) (rj-1024x768x16x144) (rj-1024x768x16x150) (rj-1024x768x16x170) (rj-1024x768x16x200) (rj-1024x768x16x240) (rj-1088x612x16x60) (rj-1088x612x16x70) (rj-1088x612x16x72) (rj-1088x612x16x75) (rj-1088x612x16x85) (rj-1088x612x16x100) (rj-1088x612x16x120) (rj-1088x612x16x140) (rj-1088x612x16x144) (rj-1088x612x16x150) (rj-1088x612x16x170) (rj-1088x612x16x200) (rj-1088x612x16x240) (1152x864x16x60) (rj-1152x864x16x70) (rj-1152x864x16x72) (rj-1152x864x16x75) (rj-1152x864x16x85) (rj-1152x864x16x100) (rj-1152x864x16x120) (rj-1152x864x16x140) (rj-1152x864x16x144) (rj-1152x864x16x150) (rj-1152x864x16x170) (rj-1152x864x16x200) (1280x720x16x60) (rj-1280x720x16x70) (rj-1280x720x16x72) (rj-1280x720x16x75) (rj-1280x720x16x85) (rj-1280x720x16x100) (rj-1280x720x16x120) (rj-1280x720x16x140) (rj-1280x720x16x144) (rj-1280x720x16x150) (rj-1280x720x16x170) (1280x768x16x60) (rj-1280x768x16x70) (rj-1280x768x16x72) (rj-1280x768x16x75) (rj-1280x768x16x85) (rj-1280x768x16x100) (rj-1280x768x16x120) (rj-1280x768x16x140) (rj-1280x768x16x144) (rj-1280x768x16x150) (rj-1280x768x16x170) (1280x800x16x60) (rj-1280x800x16x70) (rj-1280x800x16x72) (rj-1280x800x16x75) (rj-1280x800x16x85) (rj-1280x800x16x100) (rj-1280x800x16x120) (rj-1280x800x16x140) (rj-1280x800x16x144) (rj-1280x800x16x150) (rj-1280x800x16x170) (1280x960x16x60) (rj-1280x960x16x70) (rj-1280x960x16x72) (rj-1280x960x16x75) (rj-1280x960x16x85) (rj-1280x960x16x100) (rj-1280x960x16x120) (rj-1280x960x16x140) (rj-1280x960x16x144) (rj-1280x960x16x150) (rj-1280x960x16x170) (1280x1024x16x60) (rj-1280x1024x16x70) (rj-1280x1024x16x72) (rj-1280x1024x16x75) (rj-1280x1024x16x85) (rj-1280x1024x16x100) (rj-1280x1024x16x120) (rj-1280x1024x16x140) (rj-1280x1024x16x144) (rj-1280x1024x16x150) (rj-1280x1024x16x170) (1360x768x16x60) (rj-1360x768x16x70) (rj-1360x768x16x72) (rj-1360x768x16x75) (rj-1360x768x16x85) (rj-1360x768x16x100) (rj-1360x768x16x120) (rj-1360x768x16x140) (rj-1360x768x16x144) (rj-1360x768x16x150) (rj-1360x768x16x170) (1600x900x16x60) (rj-1600x900x16x70) (rj-1600x900x16x72) (rj-1600x900x16x75) (rj-1600x900x16x85) (rj-1600x900x16x100) (rj-1600x900x16x120) (rj-1600x900x16x140) (rj-1600x900x16x144) (rj-1600x900x16x150) (1600x1024x16x60) (rj-1600x1024x16x70) (rj-1600x1024x16x72) (rj-1600x1024x16x75) (rj-1600x1024x16x85) (rj-1600x1024x16x100) (rj-1600x1024x16x120) (1600x1200x16x60) (rj-1600x1200x16x70) (rj-1600x1200x16x72) (rj-1600x1200x16x75) (rj-1600x1200x16x85) (rj-1600x1200x16x100) (rj-1600x1200x16x120) (1920x1080x16x30) (1920x1080x16x60) (rj-1920x1080x16x70) (rj-1920x1080x16x72) (rj-1920x1080x16x75) (rj-1920x1080x16x85) (rj-1920x1080x16x100) (1920x1200x16x60) (rj-1920x1200x16x70) (rj-1920x1200x16x72) (rj-1920x1200x16x75) (rj-1920x1200x16x85) (rj-1920x1200x16x100) (1920x1440x16x60) (rj-1920x1440x16x70) (rj-1920x1440x16x72) (rj-1920x1440x16x75) (rj-1920x1440x16x85) (rj-2048x1536x16x60) (rj-2048x1536x16x70) (rj-2048x1536x16x72) (rj-2048x1536x16x75) (rj-640x480x32x70) (rj-640x480x32x72) (rj-640x480x32x75) (rj-640x480x32x85) (rj-640x480x32x100) (rj-640x480x32x120) (rj-640x480x32x140) (rj-640x480x32x144) (rj-640x480x32x150) (rj-640x480x32x170) (rj-640x480x32x200) (rj-640x480x32x240) (rj-720x480x32x60) (rj-720x576x32x60) (rj-800x600x32x70) (rj-800x600x32x72) (rj-800x600x32x75) (rj-800x600x32x85) (rj-800x600x32x100) (rj-800x600x32x120) (rj-800x600x32x140) (rj-800x600x32x144) (rj-800x600x32x150) (rj-800x600x32x170) (rj-800x600x32x200) (rj-800x600x32x240) (rj-848x480x32x60) (rj-848x480x32x70) (rj-848x480x32x72) (rj-848x480x32x75) (rj-848x480x32x85) (rj-848x480x32x100) (rj-848x480x32x120) (rj-848x480x32x140) (rj-848x480x32x144) (rj-848x480x32x150) (rj-848x480x32x170) (rj-848x480x32x200) (rj-848x480x32x240) (rj-960x600x32x60) (rj-960x600x32x70) (rj-960x600x32x72) (rj-960x600x32x75) (rj-960x600x32x85) (rj-960x600x32x100) (rj-960x600x32x120) (rj-960x600x32x140) (rj-960x600x32x144) (rj-960x600x32x150) (rj-960x600x32x170) (rj-960x600x32x200) (rj-960x600x32x240) (rj-1024x768x32x70) (rj-1024x768x32x72) (rj-1024x768x32x75) (rj-1024x768x32x85) (rj-1024x768x32x100) (rj-1024x768x32x120) (rj-1024x768x32x140) (rj-1024x768x32x144) (rj-1024x768x32x150) (rj-1024x768x32x170) (rj-1024x768x32x200) (rj-1088x612x32x60) (rj-1088x612x32x70) (rj-1088x612x32x72) (rj-1088x612x32x75) (rj-1088x612x32x85) (rj-1088x612x32x100) (rj-1088x612x32x120) (rj-1088x612x32x140) (rj-1088x612x32x144) (rj-1088x612x32x150) (rj-1088x612x32x170) (rj-1088x612x32x200) (rj-1152x864x32x70) (rj-1152x864x32x72) (rj-1152x864x32x75) (rj-1152x864x32x85) (rj-1152x864x32x100) (rj-1152x864x32x120) (rj-1152x864x32x140) (rj-1152x864x32x144) (rj-1152x864x32x150) (rj-1152x864x32x170) (rj-1280x720x32x70) (rj-1280x720x32x72) (rj-1280x720x32x75) (rj-1280x720x32x85) (rj-1280x720x32x100) (rj-1280x720x32x120) (rj-1280x720x32x140) (rj-1280x720x32x144) (rj-1280x720x32x150) (rj-1280x768x32x70) (rj-1280x768x32x72) (rj-1280x768x32x75) (rj-1280x768x32x85) (rj-1280x768x32x100) (rj-1280x768x32x120) (rj-1280x768x32x140) (rj-1280x768x32x144) (rj-1280x768x32x150) (rj-1280x800x32x70) (rj-1280x800x32x72) (rj-1280x800x32x75) (rj-1280x800x32x85) (rj-1280x800x32x100) (rj-1280x800x32x120) (rj-1280x800x32x140) (rj-1280x800x32x144) (rj-1280x800x32x150) (rj-1280x960x32x70) (rj-1280x960x32x72) (rj-1280x960x32x75) (rj-1280x960x32x85) (rj-1280x960x32x100) (rj-1280x960x32x120) (rj-1280x960x32x140) (rj-1280x960x32x144) (rj-1280x960x32x150) (rj-1280x1024x32x70) (rj-1280x1024x32x72) (rj-1280x1024x32x75) (rj-1280x1024x32x85) (rj-1280x1024x32x100) (rj-1280x1024x32x120) (rj-1280x1024x32x140) (rj-1280x1024x32x144) (rj-1280x1024x32x150) (rj-1360x768x32x70) (rj-1360x768x32x72) (rj-1360x768x32x75) (rj-1360x768x32x85) (rj-1360x768x32x100) (rj-1360x768x32x120) (rj-1360x768x32x140) (rj-1360x768x32x144) (rj-1360x768x32x150) (rj-1600x900x32x70) (rj-1600x900x32x72) (rj-1600x900x32x75) (rj-1600x900x32x85) (rj-1600x900x32x100) (rj-1600x900x32x120) (rj-1600x1024x32x70) (rj-1600x1024x32x72) (rj-1600x1024x32x75) (rj-1600x1024x32x85) (rj-1600x1024x32x100) (rj-1600x1200x32x70) (rj-1600x1200x32x72) (rj-1600x1200x32x75) (rj-1600x1200x32x85) (rj-1600x1200x32x100) (rj-1920x1080x32x70) (rj-1920x1080x32x72) (rj-1920x1080x32x75) (rj-1920x1080x32x85) (rj-1920x1200x32x70) (rj-1920x1200x32x72) (rj-1920x1200x32x75) (rj-1920x1200x32x85) (rj-1920x1440x32x70) (rj-1920x1440x32x72) (rj-1920x1440x32x75) (rj-1920x1440x32x85) (rj-2048x1536x32x60) (rj-2048x1536x32x70) (rj-2048x1536x32x72) (rj-2048x1536x32x75)
directinput: searching joysticks=none
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=unable to open interface device
tmsystem: searching usb interface (1) 0=unable to open interface device
tmsystem: searching usb interface (0) 0=unable to open joystick device
tmsystem: searching usb interface (1) 0=unable to open joystick device
tminput: 0 devices found
tminput: searching for input devices...(2)
tmgl: loading font v2 texture/arial20b.tmf=(256x256) (32x255) ok
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=1297777 mus
tmcollision: 1604 triangles using 70576 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6)
tmcollision: octmin=(400.0,400.0,400.0)
tmcollision: otnodes=37 otdepth=11
tmcollision: otnmaxareas=838 otnavgareas=48 otnminsize=(312.500,312.500,61.746)
tmcollision: otareas=1803 mem=100968
tmcollision: otclppl=5608 mem=179456
tmcollision: 37 octrees, using 9620 bytes
tmcollision: total mem=360620 bytes
tmcollision: time=20479mus
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 christeneagle...
tmdairfoil: loading naca0015 ok
tmdairfoil: loading flat ok
tmdairfoil: loading naca0009 ok
directsound: register sound sound/g15-3000.wav=ok
directsound: register sound sound/g15-5000.wav=ok
directsound: register sound sound/g15-10000.wav=ok
generating shadow christeneagleshadow0=radius=2.13 bbmin=(-1.28 -1.28 -0.46) bbmax=(1.28 1.28 0.27)
sim: creating blurr=Propeller
tmmusic: off
directsound: shutdown
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
STLPilot 03-10-2005 10:58 AM
RE: cant find usb error
What video card do you have?
pezzheaddazzler 03-10-2005 01:08 PM
STLPilot 03-10-2005 01:52 PM
So ... it cannot find the USB correct? Have you tried it on another computer?
pezzheaddazzler 03-10-2005 03:36 PM
I dont have another computer with video card
I tried uninstalling and re installing software and that didnt help.
if i plug it in another machine will it show up as "new hardware"
or do i have to install software?
STLPilot 03-10-2005 04:29 PM
You don't need to install the software. Just plug it in ... plug it into the radio then go into game controllers and joysticks and see if it shows up there.
pezzheaddazzler 03-10-2005 08:51 PM
tried on another computer and it didnt show up did a search for new hardware and that didnt find it either
only my real flight controller is in box
AbuAnas 03-11-2005 02:33 PM
Hi
Make sure that u have set your Tx modulation to PPM (Pulse Positioning Modulation)
Icebird 03-11-2005 09:39 PM
I installed a USB device on a buddies computer recently, and it wouldn't recognize that anything was there. I ended up going into the Device Manager, and deleting all the USB ports. When I rebooted, they reinstalled themselves, and the problem was solved. Perhaps this would work for you?
HTH
Jim
pezzheaddazzler 03-11-2005 09:53 PM
thanks for the suggestions
radio is set for ppm
uninstalled all usb ports and they came back rebooted pc
still program cant find port
