AFPimportWizard help needed
Downloaded Codepunk's AFPinportWizard and for scenery it works great! Thanks Codepunk. My problem is that when I try to convert any Reflex aircraft it just copies the files that are there into the aircraft directory of Aerofly Pro Deluxe and does no conversion.
Am I missing something? I thought since it does an excellent job of converting the scenery from Reflex and the option for the airplanes is there that it would convert them also. HELP!! |
RE: AFPimportWizard help needed
Nope sorry. Guess I should clarify that. The tool does not convert Reflex aircraft for use in AFPD. Both software packages have their own internal format which is closed (i.e. I don't know what it is and reverse engineering would be too hard) so converting between the 2 is not possible.
O.K. Thanks for the info. Sorry to hear that. The scenery converter is great!
I would like to donate but I can only use checks. So what models do the aircraft functions operate on? |
| All times are GMT -8. The time now is 04:41 PM. |
