RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   Interface Cable Problem (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/3043525-interface-cable-problem.html)
mduslick 06-05-2005 07:35 AM
I have been using AFPD for months now (love it), but this morning when I fired up the software, the title screen came up, but there was also a pop-up box that said "searching inetrface... please wait"... but the system never finds it. My set-up is:
Windows XP
AFPD version 1.8.0.9
I use my Realfight controller plugged into one of the front USB ports in the front of the computer
The AFPD interface cable is plugged into the other front USB port
I tried unplugging and plugging back in both USB plugs (for the controller and interface cable) and when I do, I hear the audible tone I always hear (sounds sorta like a doorbell) when I plug in the devices. But the software (AFPD) still does not see the interface cable. Like I said, I have used the softeware extensively for months without any trouble, and I have not loaded any new software on this PC or done anyrhing different to it. Could my interface cable have gone bad or what?
Ian.W 06-05-2005 08:07 AM
RE: Interface Cable Problem
Is it plugged into the TX? when it searches for the interface, keep it unplugged from the TX. Ive had the same thing a few times on AFP and my wires are breaking in my interface, just a quick re-solder does the trick. If it finds the interface, click fly now and see if it works with the TX pluged in, if not, then its your interface.
mduslick 06-05-2005 08:22 AM
Here's my dilemma... the interface is not plugged into the tx. It is plugged directly into the USB port. And I'm not using my tx... I'm using the Realflight controller with the USB connector, and it is also plugged into a USB port. I checked the end of the interface cable where the plug is (not the USB plug but the other end) and there were no loose wires. The solder joints were fine.
