How I can use cable from simblaster.com in AFPD ?
I bought an USB cable from simblaster.com and I use it with FSM (6XAS 6-Channel PCM1024 Computer Radio Control System from Futaba) and it works perfectly. I also have AeroFly Pro Deluxe CD-s and I would like to use this cable (simblaster.com) but I don't have any idea how to configure it so it'll work?
RE: How I can use cable from simblaster.com in AFPD ?
This is from the AFP website for the SIMCOM ... same deal for simblaster.
Please note AeroFly Pro and AeroFly Pro Deluxe Users: This SIMCOM will not work with AFP or AFPD without an Original AFP or AFPD Interface or Commander cable attached to your computer. This cable is designed to be used as the 2nd controller only for the AFP(D) Interface version. It can also be used with the AFP(D) Commander version as the 1st or 2nd controller as long as your original AFP(D) Interface or Commander is plugged into your computer simultaneously. |
| All times are GMT -8. The time now is 04:41 PM. |
