need help on saving planes
Hi All,
I have AFPD and recently downloaded the OMP Yak54p. I love this plane and after some tweaking got it to fly perfect for me. Problem is when I got it the way I like I clicked "save as" and just added a number behind the name to distinguish it. It saved the plane and the settings I tweaked on but the plane lost all its color, it is just a white plane now. Anyone have any idea on what I can do? Thanks Z |
RE: need help on saving planes
Ok you need to copy all of the BMP file's from the original Yak folder and paste them in the new Yak folder.
(Both folders are in the "Aircraft" directory). BTW. Have you got my 4D conversion of the model???? If not here's the link: [link=http://www.rodeo.rc-sim.de/Default.htm]http://www.rodeo.rc-sim.de/Default.htm[/link] (it's dated 2005-06-13;)) MAKE SURE YOU INSTALL THE AFPD 1.8.0.19beta PATCH BEFORE INSTALLING THIS MODEL;). Hope this helps:D;). Greg. |
Greg, thanks a bunch, that worked perfectly! Also, I tried clicking on the link for the 4d conversion but it didnt work. I then went to actualy website but for some reason it wont let me download any of the planes from rodeo. Any ideas?
Z |
Try these direct links: [link=http://www.rodeo.rc-sim.de/afprodeluxe/OMP35Yak-4D_for_AFPD.exe]YAK[/link], [link=http://www.rodeo.rc-sim.de/afprodeluxe/Gilesmini-4D_for_AFPD.exe]Giles[/link] & [link=http://www.rodeo.rc-sim.de/afprodeluxe/OMP32Edge-4D_for_AFPD.exe]Edge[/link]
If that does not work I can e-mail them to you:D;)! Greg. |
Got it, thanks!!!
Last question <G>...........Instead of my 9c radio I been using a futaba trainer box to fly the sim with. Is there anyway to turn on smoke without switches on radio? Thanks again for all the help Z |
Assign the smoke to the keyboard (ie on the num pad 1 or 2 or 3 etc....).
Pleasure helping you:D;)! Greg. |
Once again, worked perfectly except when I started hovering I went from 130fps down to 10fps pretty quick!!
| All times are GMT -8. The time now is 12:41 PM. |
