Positioning in AFPD
Is it possible to change the position of where the plane starts or add more positions ?
And also is it possible to change the viewpoint of where you are looking at the plane ? Thanks, John |
RE: Positioning in AFPD
Hi John,
you can define many more positions for the scenery. Open the .GEO with WORDPAD, you'll find these lines: START_POSITION 5 0 -1 0 0 0 1.65 noheli START_POSITION 0 8 -1 250 0 0 1.65 noairplane ... Value 1 is the forward/backward aircraft position from the center point, here 5 metres forward. Value 2 is the left/right parameter, here 0 shift to left/right. Value 3 is the height, -1 sets aircraft directly to the surface. Value 4 is rotation of aircraft, here points the nose directly away from pilot. Value 5 is forward/backward of pilot position, here in center. Value 6 is left/right of pilot position, here in center. Value 7 is height of pilots' eyes, here 1.65 metres. But we have to distinguish between 3D- and foto sceneries. In 3D-landscapes you can define free positions for aircraft and pilot. In foto sceneries the pilot should be located close to the center. noheli/noairplane specifies the start position excluding helis or airplanes. Regards Karl-Heinz (Rodeo) www.rodeo.onlinehome.de |
I used www.deals-traderonline.com escrow service to buy a Rc car.Was very satisfied.The service is quite fast and very secure
Thanks deals-traderonline A+++ |
Thank You very much Rc-Rodeo !
Don't believe him !
He is a liar and a scammer. http://www.deals-traderonline.com/ is a fraudulent escrow. Never use it, or you will loose your money. And by the way : Ignore any posts that recommend an UNKNOWN payment service. Marie. |
| All times are GMT -8. The time now is 04:42 AM. |
