TMD HELP!
Hi guys,
Anyone know the TMD for PPS/4D? i made the big 40% extra with the red drops electric, now i wanna make it 4D, but cant figure out what in the TMD to change. I have been comparing it to the Slowride-4D tmd to try and make it the same, but nothing changes. Thanks! Scott[8D] |
RE: TMD HELP!
Hi Scott,
Firstly have you definitely converted it to electric? Otherwise 4D won't work. BW! Greg. |
RE: TMD HELP!
you are the Number 1 person i was hoping would respond
Yes, i have converted the 40% extra to electric, ive also had the prop changed to 4D, however, whenever i put negative pitch on (pull throttle stick back) it crashes and makes aerofly crash. the throttle also goes really high. I was wondering how you made the 33% Hangar 9 Edge 540 4D? i saw that in a video, that's why im trying to do. Thanks!! Scott |
RE: TMD HELP!
you have to change the value thing....lol make the endpoints smaller.....greg!!!! help!!!
RE: TMD HELP!
Hi Scott,
Here's some instuctions: Below is are the necessary bits of a TMD file of a VPP plane, The red lines mean that you need to change the original line to that. The blue lines mean that you need to Replace the line in the TMD of the model you are working on with this line (put it in the same place if possible). The purple arrows point to where you can change the "servo slow". The green arrows point to where you can change the pitch (IF AFPD CRASHES EXIT AFPD AND MAKE THE PITCH LESS BOTH WAYS IN THE TMD!). Hope this helps! Greg. Here's the copy of the bits you need to change in the TMD file: __________________________________________________ _______________________________________ // aerofly professional -------------------------------------------------------- // // file: xxxxxxxxxxxx.tmd // version: 1.8.0 // // type: 97 // lock: 0 // // ----------------------------------------------------------------------------- Append tmdjoint00 Joint00 Append tmdjoint00 Joint01 Append tmdjoint00 Joint02 Append tmdjoint00 Joint03 Append tmdjoint00 Joint04 Append tmdjoint00 Joint22 Append tmdjoint00 Joint23 Append tmdjoint00 Joint24 Append tmdreceiver00 Receiver Append tmdfuselage00 Fuselage Append tmdwheel00 Leftwheel Append tmdwheel00 Rightwheel Append tmdwing00 LeftWing Append tmdwing00 RightWing Append tmdwing10 Leftstabilizer Append tmdwing10 Rightstabilizer Append tmdwing11 Stabilizer Append tmdservo00 ServoRudder Append tmdservo00 ServoElevator Append tmdservo00 ServoLeftAileron Append tmdservo00 ServoRightAileron Append tmdpropeller10 Propeller Append tmdengine10 Engine Append tmdservo00 ServoThrottle Append tmdservo00 ServoPitch - - - - - - cd Propeller/ X = tmvector4r( 0.0000, 1.0000, 0.0000, 0 ) Y = tmvector4r( 0.0000, 0.0000, 1.0000, 0 ) Z = tmvector4r( 1.0000, 0.0000, 0.0000, 0 ) R = tmvector4r( 0.2399, 0.0063, 0.0064, 1 ) Geometry( "~Geometry/Propeller/" ) Mass = 0.01 RangeMassMax = 0.02 RangeMassMin = 0.005 Inertia = { 0.0004, 0.0000, 0.0000, 0.0000, 0.0000, 0.0004, 0.0000, 0.0000, 0.0000, 0.0000, 0.0004, 0.0000, 0.0000, 0.0000, 0.0000, 1.0000 } Kn = 4000 Dn = 10 Dv = 5 Radius = 0.114306 RangeRadiusMax = 0.269592 RangeRadiusMin = 0.067398 Pitch = 0.126628 PitchMin = -0.04 <<<<<<<<<<<<&l t;<<<<<<<<<<< PitchMax = 0.09 <<<<<<<<<<<<&l t;<<<<<<<<<<< Cqq = 0.01 DragLateral = 0.45 Engine = ~Aircraft/Engine/ PitchControl = ~Aircraft/ServoPitch/MechLink cd ../ cd Engine/ X = tmvector4r( 1.0000, 0.0000, 0.0000, 0 ) Y = tmvector4r( 0.0000, 1.0000, 0.0000, 0 ) Z = tmvector4r( 0.0000, 0.0000, 1.0000, 0 ) R = tmvector4r( 0.0727, 0.0000 , -0.0109, 1 ) Geometry( "~Geometry/Engine/" ) Mass = 0.064 RangeMassMax = 0 RangeMassMin = 0 Inertia = { 0.0000, 0.0000, -0.0001, 0.0000, 0.0000, 0.0002, 0.0000, 0.0000, -0.0001, 0.0000, 0.0002, 0.0000, 0.0000, 0.0000, 0.0000, 0.0340 } Kn = 4000 Dn = 10 Dv = 5 - - - - - cd ServoThrottle/ SignalIn = ~Aircraft/Receiver/Out(20) P0 = 0 P1 = 1 P2 = 0 P3 = 0 PFirst = 0 Vmax = 50 X = tmvector4r( 1.0000, 0.0000, 0.0000, 0 ) Y = tmvector4r( 0.0000, 1.0000, 0.0000, 0 ) Z = tmvector4r( 0.0000, 0.0000, 1.0000, 0 ) R = tmvector4r( 0.0000, 0.0000, 0.0000, 1 ) Mass = 0 RangeMassMax = 0 RangeMassMin = 0 Inertia = { 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 } Kn = 1000 Dn = 20 Dv = 5 cd ../ cd ServoPitch/ SignalIn = ~Aircraft/Receiver/Out(0) P0 = 0 P1 = 1 P2 = 0 P3 = 0 PFirst = 0 Vmax = 50<<<<<<<<<<<<&l t;<<<<<<<<<<<< <<<<<<<<<<<<&l t;<<<<<<<<<<< X = tmvector4r( 1.0000, 0.0000, 0.0000, 0 ) Y = tmvector4r( 0.0000, 1.0000, 0.0000, 0 ) Z = tmvector4r( 0.0000, 0.0000, 1.0000, 0 ) R = tmvector4r( 0.0000, 0.0000, 0.0000, 1 ) Mass = 0 RangeMassMax = 0 RangeMassMin = 0 Inertia = { 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 } Kn = 1000 Dn = 20 Dv = 5 cd ../ |
RE: TMD HELP!
now for some reason the plane doesnt even show up when i hit fly, the view port looks at nothing, however it falls, the plane that isnt there crashes, and AFPD crashes and closes.
lol this is fun! hehe I think it's getting there though Scott |
RE: TMD HELP!
Have you tried converting an electric plane such as the standerd Monsoon to 4D??? Then you may be able to tell if you are doing it wrong or not.
BW! Greg. |
| All times are GMT -8. The time now is 09:58 AM. |
