jumpy throttle in AFPD
I have just got my AFPD . I use it with my SANWA RD 8000 and every thing is ok except one thing , throttle is very jumpy ,without using throttle trim on my radio the airplane runs immediately!!! when I trime throttle on my radio to a lower position the aireplane doesn't run but with a little throttle movement the level of throttle is almost 50% !!!! as a result I can not do Torque rolling .
can anyone help me ? |
RE: jumpy throttle in AFPD
Have you tried re-calibrating? If the cord is bad it will be replaced for free ... at least here in the US.
I have tried to re-calibrat it many times and the result is the same .Do you think problem is the interface ? It works fine on the other chanels
thanks |
Yup if you lost a channel means the cord needs replacing. Contact local distributor, I guess Ikarus Germany???
thank you
During calibration you have to set ALL sticks to the center, even the throttle stick.
Regards Karl-Heinz (Rodeo) www.rodeo.onlinehome.de |
I didn't know this ! I am going to try it
thank you |
Thank you very very much you solved the problem :)
Great, have fun!
| All times are GMT -8. The time now is 09:09 AM. |
