usb cable ? ? ?
I loaded the AFPD and I am getting a "Unable to locate the usb interface cable." I Downloaded the FMS flight sim online and everything works fine. I am using a Hitec Flash 5 Tx and a Hitec usb cable. Any help would be very much appreciated Thanx in an advance.
RE: usb cable ? ? ?
AFPD will work only with the original usb interface, due to copyright protection. If you wish to use the two-player mode with a slave usb cable, you will still need to plug in the original usb interface.
| All times are GMT -8. The time now is 01:21 AM. |
