RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   Does all models tends to turn? (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/7341922-does-all-models-tends-turn.html)
dm88 04-06-2008 02:37 PM
Hello,
I'd like to know if all of the models in AFPD tends to turn without transmitter trimming (as sometimes in real flying),cause i've noticed this recently.Maybe its just problem with my radio? (Hitec Flash 5SX).I've calibrated it properly, however it's pretty annoying when the model is making self turns at f3a maneuvers etc.Just want to know if its common.
rajul 04-06-2008 06:59 PM
RE: Does all models tends to turn?
Are all the planes having this problem or only certain models? Which channels or control surfaces are affected? If you're using dual rates, did you calibrate at high rates? Before you calibrate, did you disable all program mixes and set all trims to neutral?
dm88 04-07-2008 02:04 AM
Well i would say almost every model is having this.The affected channel is no doubtly rudder cause the airplane is turning even on the strip at start.The dual rates are set for 100% and mixes are turned off.I had reseted the radio to the factory adjustments and have calibrated it again but still no result.The wierd thing is that when on the ground (or even in air [chase cam]) everything looks fine,i mean the rudder is straight without any deflection but model still turning.Please try this aircraft.
[link=http://www.2shared.com/file/3106137/40bc0594/angels.html]Angel S von Sebart[/link]
rajul 04-07-2008 09:51 PM
1 Attachment(s)
I received the photo of your interface cable and it clearly a pirated version. This explains all the problems you are having. Discussion of illegal softwares and products is against RCU policy and we certainly do not support it here. Additionally, you could be banned in RCU.
