RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   Help i cant fly either (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/8289088-help-i-cant-fly-either.html)
eclipse111 12-27-2008 10:46 PM
im using a spektrum dx61 controller
comp specs
amd althon 64 64 3000+
1gig on ram
nvidia 6600
i have addons 1-2 and 3
i initially installed all 3 as per the instructions but have since removed the program and only reinstalled 1 and 2
version # 1.11.07.09
tm log tm: Library Version 4.4, Copyright (C) 1999-2007, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 1825065595
tmsystem: cpu type=(nlogical=1) (nphysical=1) (no hyper-threading)
tmsystem: cpu=1809 Mhz
tmsystem: memory=(physical=1023MB, avail=629MB) (virtual=2047MB, avail=1897MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.11.7.9, Copyright (C) 1998-2007 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
openal: register sound sound/beep.wav=(0, rd=100.00) ok
openal: register sound sound/balloon.wav=(1, rd=100.00) ok
openal: register sound sound/crash.wav=(2, rd=100.00) ok
openal: register sound sound/splash.wav=(3, rd=100.00) ok
openal: register sound sound/glider.wav=(4, rd=2.00) ok
openal: register sound sound/glider2.wav=(5, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(6, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(7, rd=5.00) ok
openal: register sound sound/glider.wav=(already registered)(already registered)(8, rd=2.00) ok
openal: register sound sound/glider2.wav=(already registered)(already registered)(9, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(already registered)(already registered)(10, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(already registered)(already registered)(11, rd=5.00) ok
tmgl: failed to load texture texture/cockpitmain.bmp
tmgl: loading geometry objects/horizon.obj= ok
afdesign: init ok
tmgl: loading geometry objects/card.tgo= ok
tmgl: loading geometry objects/pylon.obj= ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=747x550) (screen=1280x1024) (32bpp) (60Hz) (window)
openal: init (default=Generic Hardware) (0:Generic Hardware) (1:Generic Software) (version=1.1) (1.1) (Generic Hardware) (Generic Hardware) ok
init pixelformat=ok
gl: vendor=NVIDIA Corporation, renderer=GeForce 6600 GT/PCI/SSE2/3DNOW!, version=2.1.2, opengl version=2.1
(viewport=4096x4096) (texturesize=4096) (stencil=8)
gl extensions=GL_ARB_color_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_timer_query GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
wgl extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_extensions_string WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
gl: extensions=(multitexture) (framebuffer) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps) (shader objects)
wgl: extensions=(wglpixelformat) (swapcontrol) (multisample)
gl: reducing max texture size from 4096 to 2048
tmsystem: fullscreen modes=(rj-640x480x16x60) (rj-640x480x32x60) (rj-640x480x16x70) (rj-640x480x16x72) (rj-640x480x16x75) (rj-720x480x16x60) (rj-720x576x16x60) (800x600x16x60) (rj-800x600x16x70) (rj-800x600x16x72) (rj-800x600x16x75) (rj-848x480x16x60) (rj-848x480x16x70) (rj-848x480x16x72) (rj-848x480x16x75) (rj-960x600x16x60) (rj-960x600x16x70) (rj-960x600x16x72) (rj-960x600x16x75) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x72) (rj-1024x768x16x75) (1152x864x16x60) (rj-1152x864x16x70) (rj-1152x864x16x72) (rj-1152x864x16x75) (1280x720x16x60) (rj-1280x720x16x70) (rj-1280x720x16x72) (rj-1280x720x16x75) (1280x768x16x60) (rj-1280x768x16x70) (rj-1280x768x16x72) (rj-1280x768x16x75) (1280x800x16x60) (rj-1280x800x16x70) (rj-1280x800x16x72) (rj-1280x800x16x75) (1280x960x16x60) (rj-1280x960x16x70) (rj-1280x960x16x72) (rj-1280x960x16x75) (1280x1024x16x60) (rj-1280x1024x16x70) (rj-1280x1024x16x72) (rj-1280x1024x16x75) (rj-640x480x32x70) (rj-640x480x32x72) (rj-640x480x32x75) (rj-720x480x32x60) (rj-720x576x32x60) (rj-800x600x32x70) (rj-800x600x32x72) (rj-800x600x32x75) (rj-848x480x32x60) (rj-848x480x32x70) (rj-848x480x32x72) (rj-848x480x32x75) (rj-960x600x32x60) (rj-960x600x32x70) (rj-960x600x32x72) (rj-960x600x32x75) (rj-1024x768x32x70) (rj-1024x768x32x72) (rj-1024x768x32x75) (rj-1152x864x32x70) (rj-1152x864x32x72) (rj-1152x864x32x75) (rj-1280x720x32x70) (rj-1280x720x32x72) (rj-1280x720x32x75) (rj-1280x768x32x70) (rj-1280x768x32x72) (rj-1280x768x32x75) (rj-1280x800x32x70) (rj-1280x800x32x72) (rj-1280x800x32x75) (rj-1280x960x32x70) (rj-1280x960x32x72) (rj-1280x960x32x75) (rj-1280x1024x32x70) (rj-1280x1024x32x72) (rj-1280x1024x32x75)
directinput: searching joysticks=none
(1::) (1::) (1:programobject:)
framebuffer object created (1024, 1024)
framebuffer object created (256, 256)
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=radiointerface
tmsystem: searching usb interface (1) 1=unable to open interface device
tmsystem: searching usb interface (0) 1=unable to open joystick device
tmsystem: searching usb interface (1) 1=unable to open joystick device
tminput: 1 devices found
tminput: searching for input devices...(2)
tmsystem: searching dummy usb interface (0) 1=unable to open interface device
tmsystem: searching dummy usb interface (0) 1=unable to open joystick device
tminput: checking for joystick 0=fail
sim: loading scenery scenery/neuenbuerg.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (indoor)
sim: start position 2 (indoor)
sim: start position 3 (indoor)
sim: start position 4 (indoor)
sim: start position 5 (indoor)
sim: ballons=10 (-7.00,-7.00,2.00) (-19.00,7.00,6.00)
tmgl: loading geometry objects/balloon.obj= ok
sim: dragrace=(32.00,270.00)
sim: spotarea=(10.00,10.00)
sim: load texture grid 5x5 (pano=0) (compress=1) named neuenbuerg/neuenbuerg=(3.600x4.000) (5x5) (20x10)
sim: sphere params(0)=-0.0500 0.0000 -0.0300
sim: loading object scenery/neuenbuerg/neuenbuerg.obj=tmgl: loading geometry scenery/neuenbuerg/neuenbuerg.obj= ok
ok
sim: loading time=218548 mus
sim: 1 photo scenes
tmcollision: 7681 triangles using 983168 bytes
tmcollision: omin=(-4000.1,-4000.0,-0.0) omax=(4000.0,4000.0,10.5) octmin=(10.0,10.0,10.0)
tmcollision: otnodes=245 otendnodes=123 otdepth=21 otlistareas=188864
tmcollision: otnmaxareas=404 otnavgareas=87 otnminsize=(7.813,7.813,5.272)
tmcollision: otareas=10786 mem=1026312
tmcollision: 245 octrees, using 37240 bytes
tmcollision: total mem=1063552 bytes
tmcollision: time=0.18s
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 christeneagle...
tmgl: loading geometry aircraft/christeneagle/christeneagle.obj= ok
tmdairfoil: loading naca0015 ok
tmdairfoil: loading flat ok
tmdairfoil: loading naca0009 ok
openal: register sound sound/g15-3000.wav=(12, rd=4.63) ok
openal: register sound sound/g15-5000.wav=(13, rd=4.63) ok
openal: register sound sound/g15-10000.wav=(14, rd=4.63) ok
generating shadow 0=radius=2.35 bbmin=(-1.41 -1.41 -0.51) bbmax=(1.41 1.41 0.29)
sim: creating blurr=Propeller
loading input device calibration config/radio0.tmc=ok
tmmusic: off
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=47007) -36 4) 88 (608EFDA6)
openal: loading sound/beep.wav= ok 0 145892184 145922672
openal: loading sound/balloon.wav= ok 1 145892256 145936464
openal: loading sound/crash.wav= ok 2 145892328 222545440
openal: loading sound/splash.wav= ok 3 145892400 222585088
openal: loading sound/glider.wav= ok 4 145892472 222857600
openal: loading sound/glider2.wav= ok 5 222858904 145937768
openal: loading sound/glider.wav= ok 6 145939072 145939120
openal: loading sound/glider2.wav= ok 7 145940448 223904960
openal: loading sound/glider.wav= ok 8 223906288 145940496
openal: loading sound/glider2.wav= ok 9 145941824 145941872
openal: loading sound/glider.wav= ok 10 145943200 145943248
openal: loading sound/glider2.wav= ok 11 145944576 145944624
openal: loading sound/g15-3000.wav= ok 12 145945952 145946000
openal: loading sound/g15-5000.wav= ok 13 145947328 145947376
openal: loading sound/g15-10000.wav= ok 14 223491776 223491824
sim: switching to simulation mode...
tmdynamics: simulation started
sim: aircraft=(-5.00,-6.00,0.51), viewer=(0.00,0.00,1.65)
sim: 2385 memory blocks using 15669056 bytes
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmdynamics: simulation stopped
saving inputdevice calibration config/radio0.tmc=ok
tmgl: loading geometry aircraft/heli60/heli60.obj= ok
openal: register sound sound/blade1.wav=(12, rd=3.30) ok
openal: register sound sound/gheli1.wav=(13, rd=3.30) ok
generating shadow 0=radius=1.57 bbmin=(-1.08 -1.08 -0.23) bbmax=(1.08 1.08 0.23)
sim: creating blurr=Rotor
sim: creating blurr=TailRotor
openal: loading sound/blade1.wav= ok 12 145946000 145947376
openal: loading sound/gheli1.wav= ok 13 145946048 223491824
sim: aircraft=(-5.00,-6.00,0.23), viewer=(0.00,0.00,1.65)
sim: 2251 memory blocks using 14956512 bytes
pls help
rajul 12-27-2008 11:07 PM
RE: Help i cant fly either
Hi, what is the exact error message or problem you are facing? Could you describe the type of usb interface cable you are using, and the type of adapter cable? Thx
eclipse111 12-27-2008 11:20 PM
there is no error message, the screen flashes black and stays at the initial screen when i hit fly
the cable white with an ovalish black box on it, i have bridged the wires to make it a mono so it will work with the spektrum
i can move the controls in the menus with the controller
rajul 12-27-2008 11:35 PM
Hi, there could be a few possibilities that contribute to this problem:
1. You have not installed the correct AFPD patch. Try installing the latest patch 1.11.7.21 http://www.aerofly.com/www/downloads.html
2. It may be a problem with the graphic card driver. Update your driver and see if the problem goes away. You also need to ensure that your graphics card hardware acceleration is at maximum.
3. It could also be an overheating problem in the computer or card incompatibilities. Ensure your computer is properly vented.
4. The problem may also be the sound card driver. Update your driver and see if the problem goes away.
5. If you're using an on-board sound card, you may want to try disabling the directsound hardware acceleration.To change the audio hardware acceleration setting:
1) Click Start, and then click Run.
2) In the Open box, type dxdiag, and then click OK.
3) Click the Sound tab.
4) Under DirectX Features, move the Hardware Sound Acceleration Level slider all the way to the left (no acceleration).
5) Click Exit.
eclipse111 12-27-2008 11:40 PM
thanks for the quick replys
ill try that stuff now
i just turned my sound on and when i hit fly the aircraft makes noise but remains at the initial screen
if that helps at all
rajul 12-27-2008 11:43 PM
Yes, pls go through my suggestions step by step. Let me know how it works out and I'll follow up with you later.
eclipse111 12-27-2008 11:51 PM
No luck
i have updated my card driver
i have updated with the new patch
the computer is vented well and was cleaned out recently
im using the onboard sound card and have changed the acceleration setting
still remains in the initial screen after briefly flashing black after hitting fly
sound of the helicopter plays
rajul 12-28-2008 12:15 AM
Pls post you latest tmlog file. Thx
eclipse111 12-28-2008 12:18 AM
(double post -removed)
eclipse111 12-28-2008 12:22 AM
tmsystem: init random with 187690897
tmsystem: memory=(physical=1023MB, avail=632MB) (virtual=2047MB, avail=1897MB)
afdesign: init ok
init window=(window=801x602) (screen=1280x1024) (32bpp) (60Hz) (window)
openal: init (default=Generic Software) (0:Generic Software) (version=1.1) (1.1) (Generic Software) (Generic Software Compatibility Mode) ok
init pixelformat=ok
tmsystem: searching usb interface (0) 0=unable to open interface device
tmsystem: searching usb interface (1) 0=unable to open interface device
tmsystem: searching usb interface (0) 0=unable to open joystick device
tmsystem: searching usb interface (1) 0=unable to open joystick device
tminput: 0 devices found
ok
sim: loading time=244407 mus
sim: 1 photo scenes
tmcollision: time=0.20s
sim: loading aircraft 1 ah64...
tmgl: loading geometry aircraft/ah64/ah64.obj= ok
openal: register sound sound/heli1.wav=(12, rd=5.21) ok
openal: register sound sound/f14.wav=(13, rd=5.21) ok
openal: register sound sound/f14.wav=(already registered)(14, rd=5.21) ok
generating shadow 0=radius=2.05 bbmin=(-1.36 -1.36 -0.28) bbmax=(1.36 1.36 0.33)
tmmusic: off
openal: shutdown=ok
directinput: shutdown
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
rajul 12-28-2008 12:36 AM
Hi, did you download and install patch 1.11.7.21? Your AFPD version has not been updated. Pls also post a photo of your usb interface cable for my verification. Thx
eclipse111 12-28-2008 12:40 AM
hmm it did say it had successfully installed, confussed...
ill take a photo now
eclipse111 12-28-2008 12:50 AM
http://i255.photobucket.com/albums/h...w/DSC_0006.jpg
http://i255.photobucket.com/albums/h...w/DSC_0005.jpg
eclipse111 12-28-2008 12:55 AM
ok so i reinstalled the patch and it is working fine, no idea what went wrong last time
thanks for your help rajul, i was this close to returning it
rajul 12-28-2008 12:59 AM
Well done mate! Enjoy
PeterZ 03-11-2009 04:02 AM
Just want to say thanks to the original poster and respondent.
Had the same problem - after pressing the FLY button I got the black screen flash up for 0.5sec then back to the main screen.
Followed the advice suggested of installing patch 1.11.07.21 and that fixed the problem! I'm up and flying! [8D]
It says on the official patch download site that early graphics cards (Nvidia GeForce 6000 or earlier) are not supported by this patch. Well, I have a Nvidia GeForce FX5200 card and all is working fine with the latest patch.
unit53 11-03-2010 05:02 PM
having the same issue exactly,,im using windows 7 home premium ,,and using a nvidia ge force 9500 gt card,,,just purchased and updated,,,any suggestions anyone???
