RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   Cable problems (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/8320845-cable-problems.html)
mrfliboy 01-05-2009 09:36 AM
Cable problems
1 Attachment(s)
Good morning,
I picked up the Aerofly Deluxe package with this cable setup. I've had no luck using my Futaba 7C tx. I am able to get it to semi work using a G3 Realflight controller. (everything works except throttle). What is my best option to be able to use my 7C Tx? Thanks afor any help.
Jon Earley
rajul 01-05-2009 09:52 AM
RE: Cable problems
Jon, did you set your radio to PPM mode? When you plug in the adapter cable into the 7C (radio turned off), does the radio turn on automatically? What is the version number printed on the disk? Did you install any patch? Thanks
mrfliboy 01-05-2009 10:39 AM
RE: Cable problems
Thanks for the reply Mark,
Radio is PPM mode. Radio does not turn on. Disk version is 1.8.0.17 Version on my computer is 1.9.1.1 I did install the latest I believe update. Thanks again
mrfliboy 01-05-2009 05:51 PM
RE: Cable problems
A little update I have gotten the G3 controller to properly work. One step done anyway.
rajul 01-05-2009 06:00 PM
RE: Cable problems
Try this. Turn on the radio manually using the main switch (pls remove your radio module or crystal first), then plug in the adapter cable before you activate AFPD
mrfliboy 01-05-2009 08:15 PM
RE: Cable problems
I tried what you suggested still no Tx recognized.
rajul 01-05-2009 08:40 PM
RE: Cable problems
Pls check if you disabled the trainer mode in the radio. Also pls ensure that the connectors between the usb cable and adapter cable, and also between the adapter cable and radio, are completely pushed in.
Which addons did you install?
mrfliboy 01-05-2009 09:59 PM
RE: Cable problems
Trainer is on inh. I notice that my trainer switch on the Tx is sticking. I'll try and borrow another 7C radio and do more checking. I'll keep you updated. Thanks again for the help so far. I'm sure I'll be back
Added Add one is all.
rajul 01-05-2009 10:03 PM
RE: Cable problems
You missed my question: did you install any addons?
mrfliboy 01-12-2009 10:33 AM
RE: Cable problems
Yes I installed ADD-ON 1. I have had no luck locating another 7c radio either yet.
rajul 01-12-2009 10:37 AM
RE: Cable problems
Pls download and install patch 1.9.7.11 here http://www.ipacs.de/download/afpd190711.exe
mrfliboy 01-12-2009 03:34 PM
RE: Cable problems
ORIGINAL: rajul
Patch installed still no go. I also tried powering radio first and than Aerofly still no go. The latest patch is showing up on the screen installed.
No power to radio from USB either.
rajul 01-12-2009 07:51 PM
RE: Cable problems
Try removing the crystals and switch on manually.
Also, pls check that in the controls menu, you selected transmitter instead of joystick for aircraft 1
mrfliboy 01-13-2009 03:34 PM
RE: Cable problems
ORIGINAL: rajul
Tried all the above still a no go. Crystals were already removed, power on Tx, Controls menu is Transmitter Aircraft One.
No Tx detected.
rajul 01-13-2009 06:06 PM
RE: Cable problems
Hmmm, then it could only mean two things - a wiring connection problem or an incompatibility issue with 7c. To eliminate the wiring issue, you could try to borrow a different type of Futaba radio from a friend e.g. 9c and see if that works.
mrfliboy 01-14-2009 07:35 AM
RE: Cable problems
ORIGINAL: rajul
I'll work on the borrowing a radio idea. Thanks for all the help so far. As far as wiring goes, what is the connection points we are looking for in the radio thru the trainer port?
rajul 01-14-2009 07:46 AM
RE: Cable problems
Do you have a multimeter? You could probe the connections in the Futaba adapter you have. Since the adapter worked with your G3 controller, I would say that it is in good condition.
mrfliboy 01-14-2009 07:59 AM
RE: Cable problems
ORIGINAL: rajul
Yes I do have a multimeter. What specific readings am I looking for?
I also did some searching on the 7C trainer port.
http://www.rcgroups.com/forums/showthread.php?t=282138
http://www.rcgroups.com/forums/showthread.php?t=301489
I'll be checking the to see if my 7C has the throttle timer bug tonite also.
Once again thanks for all the help.
rajul 01-14-2009 08:02 AM
RE: Cable problems
Just to confirm, did you use the same adapter with the G3 controller?
mrfliboy 01-14-2009 08:44 AM
RE: Cable problems
ORIGINAL: rajul
Yes same adapter
rajul 01-14-2009 08:49 AM
RE: Cable problems
Thanks for the confirmation. The adapter is good. Hopefully, you can get hold of the Futaba radio soon.
mrfliboy 01-15-2009 09:40 AM
RE: Cable problems
Radio is being sent out. Hopefully this will be the fix. Thanks for all the help- Mike
mrfliboy 01-23-2009 04:17 PM
RE: Cable problems
Well, I got the radio back. $50 later and still no go. Nothing has changed. Whats next Mark?
rajul 01-23-2009 07:16 PM
RE: Cable problems
There seem to be some incompatibility with 7C. Pls try another Futaba radio e.g. 9C for confirmation.
mrfliboy 01-27-2009 02:33 PM
RE: Cable problems
Well I was able this weekend to try my cable with a good working Spektrum adapter with a DX7 and it was a no go. A buddy brought his adpater only over along with his radio he had been using on his Aerofly. And we were not able to get it to work. I believe its in the dongle?
