Problem when calibrating in AFPD
Hi guys,
Just wondering if anybody has had a problem arise after doing a calibration step in AFPD when hooked up to a Spektrum6, My problem is that channel six has the jitters even after doing the full travel calibrate of the aileron stick, The ailerons work and i can fly the sim models but the jitters are always there and chewing up loads of processor time handling the tiny high frequency movements of channel six, It only started after doing a calibrate step?? Cheers,paul |
RE: Problem when calibrating in AFPD
Hi Paul, could be a grounding issue. Lay your hands on and off the transmitter's faceplate, and see if the jitter still continues. If you're using dual rates, try calibrating at high rates.
| All times are GMT -8. The time now is 01:26 AM. |
